Dracov's CarPC. Stock Navi replacement DIY. Status: in Progress
Old Jul 8, 2010 | 08:45 PM
  #46
Dracov's Avatar
I put a little white lithium grease on the cable. but even without it, it should be possible.
The trick is to have it run above the white plastic that is in the rail.
Takes a lot of patient, figure out the position of the cable without putting radio back in the place, that way you can see how the mechanism gets up and down and where it gets stuck.
Hope that helps,
Dracov.
Old Jul 8, 2010 | 09:15 PM
  #47
blAk mAx's Avatar
anymore pics of the disassembled xenarc screen?
Old Jul 8, 2010 | 10:10 PM
  #48
Dracov's Avatar
Some more pics of the older version of xenarc. The one im selling is newer and its gainboard is a little smaller.
Attached Thumbnails Dracov's CarPC. Stock Navi replacement DIY. Status: in Progress-009.jpg   Dracov's CarPC. Stock Navi replacement DIY. Status: in Progress-008.jpg   Dracov's CarPC. Stock Navi replacement DIY. Status: in Progress-005.jpg
Old Jul 9, 2010 | 12:48 AM
  #49
Jaladdin's Avatar
Thanks that actually helps a lot. My only question now is whether or not your screen actually moves. My vga cable seems impossibly thick to run alongside that track.
Old Jul 9, 2010 | 12:54 AM
  #50
Dracov's Avatar
Yea, my screen moves up and down.
Heres the pic that hopefully will help you position the cable.
Attached Thumbnails Dracov's CarPC. Stock Navi replacement DIY. Status: in Progress-vgacable.jpg
Old Jul 9, 2010 | 01:15 AM
  #51
Jaladdin's Avatar
Reading back I came off as sort of a jackass, that wasn't the intention. When I read Plastic tab i though the one to the left of that in the picture.
Thanks a lot! I will rework it tomorrow and chime back in.
Can't wait to get this thing in the car finally. Had a set up in my previous car (Prelude), and you don't realize how much you rely on it until it's not there.
Old Jul 9, 2010 | 08:07 PM
  #52
Jaladdin's Avatar
Got it work! Thanks a lot bro. I basically rethought the way I was routing it and boom! worked fine
Old Jul 10, 2010 | 06:11 PM
  #53
Dracov's Avatar
np. Good luck!
Old Jul 13, 2010 | 08:28 PM
  #54
thehump's Avatar
Thanks Blak Max,
What brand and model are the two screens you tried...
really appreciate the help...! especially with the PIC of the stock screen... that is strange, I will take a pic later tonight of the stock screen I have, comparing the 03 04 and the 05-07 i bought by mistake... with a measuring tape... the pic you show clearly shows 7inch screen... my pop out mechanism for the 03 04 looks identical to yours....
Basically, with the unit I am trying to fit, Lilliput EBY701, I find I will have to cut out the following (in red) to get it to fit as per the attached jpeg... Did you have to do any similar cutting?
Attached Thumbnails Dracov's CarPC. Stock Navi replacement DIY. Status: in Progress-screen_red.jpg
Old Jul 13, 2010 | 10:37 PM
  #55
blAk mAx's Avatar
Yea I did some dremeling when I had tried to put in the other 7" screen. The screen not installed is an eBay screen from china or japan that I got maybe 8 years back. It's made by Super. The screen that I have in there now is from a portable toshiba DVD payer. Only trouble I'm having is with mother board placement. My final plans is to have this 7" screen and an 8" touch screen under it.. I may have to go with 2 touchscreens if the mother boards run smaller
Old Jul 13, 2010 | 11:17 PM
  #56
Dracov's Avatar
my touchscreen that fits perfectly in the 05-07 and also 03-04 (according to nyqueenz) is still for sale.
$270 shipped.
Old Jul 21, 2010 | 11:02 AM
  #57
Darkblizz's Avatar
is there anything you could put in place of the old navigation buttons?
Old Jul 28, 2010 | 02:32 AM
  #58
nyqueenz's Avatar
i have a prob i have the Xenarc 700TSV 7" and the shop is tellin me it will not fit into the housing of the OEM 03-04 navi?
What do i do?
"""" I THINK I FOUND A SOLUTION FOR THE 03-04 UNITS """"
Old Jul 28, 2010 | 06:53 AM
  #59
nyqueenz's Avatar
$270 shipped.
not a prefect fit.. MB is too freakin big.. makin me unable to get the shyt i there right???
Old Jul 29, 2010 | 03:01 AM
  #60
thehump's Avatar
hey NYQueenz... i need to finish my friends project before september as new semester starts up, so i plan to try and fit my the lilliput before that time... hopefully it helps you. so far what ive seen it will require major modifications...
where is your xenarc motherboard too big (or is it the screen)? is it too thick to fit in the housing? or too wide or long? i see Dracovs is about 1 inch thick with all the mainboards and screen together...
