Rate my CarPC ^_^
Old May 17, 2011 | 09:11 AM
Shincrono's Avatar
Rate my CarPC ^_^
Old May 17, 2011 | 04:17 PM
petro2342's Avatar
Nice. Is this yours? I know you posted it, but I think I've seen this a while back ago. Really nice none the less.
If you did, did you do it yourself? How much everything cost if you don't mind me asking. I'm planning on doing it too.
Old May 19, 2011 | 01:04 AM
Shincrono's Avatar
Yea its mines
I did buy all the components but I had a pro install everything.
I think I spent like $1700 for everything including install, I can't remember exactly. I got this done like 3 years ago
Old May 19, 2011 | 02:20 AM
pythonjosh's Avatar
dude i gotta know more!
What power supply did you use? What's the name of the program you ran from windows that went into media player, etc?
Did you go with a SSD? What wireless networking adapter did you go with?
The vid was great finishing it off with the SNES emulator.
Old May 19, 2011 | 07:59 AM
Shincrono's Avatar
Power supply is the Carnetix CNX-P1900 Ver. 2.2 Dual Output 140 Watt 12V DC-DC Regulator. The program running in windows is called Centrafuse.
The computer I use is the Aopen mini pc Fits perfectly in the globe box. I put a 160GB sata hdd, its not a ssd.
Old May 19, 2011 | 08:48 AM
sexyrob's Avatar
looks nice but bootup is slow.
I'm using a stripped down version of windows xp embedded and I get from bios to deskop is 10-12 seconds.
Old May 19, 2011 | 08:50 AM
sexyrob's Avatar
also, check out this power supply. it's what I use and its awesome!
you can wire it up to turn the pc on and off for you when you turn the car on and off.
http://www.logicsupply.com/products/m3_atx
Old May 19, 2011 | 10:56 AM
faiz23's Avatar
Sexy Rob,
Do you have a carputer in your car currently. If so I might need to come check it out so i can get some pointers. I was big into MP3car and made a really nice carputer with a Travala C134 case and a Opus Power supply with built in trigger.
Old May 19, 2011 | 11:12 AM
pythonjosh's Avatar
There are some good power supplies out there, many can be configured to send a hibernate command instead of power off.
Old May 19, 2011 | 11:56 AM
sexyrob's Avatar
my carputer is built to boot up into uprev cipher for data logging / gauges. so the OS is very stripped down.
its currently sitting on my kitchen table while I optimize it. not in the car yet.
Old May 29, 2011 | 04:53 PM
sssmasss's Avatar
i would give u a 9. i have seen better.. just little better
Old Jul 25, 2011 | 11:00 PM
nohoch's Avatar
That is sweet...
Old Jul 26, 2011 | 07:52 AM
Trickstyle's Avatar
ive found literally EVERYTHING but xp embedded lol where did you get yours?
Old Jul 26, 2011 | 07:53 AM
sexyrob's Avatar
well its hard to get now, they now have a windows 7 version... and you don't really get it, you build it. microsoft has some tools for this.
Old Jul 26, 2011 | 09:01 AM
Deftronix's Avatar
I use a G.Skill pheonix pro 120GB SSD (285mb/read 275mb/write) on mine as well as boot win 7. I coulnt recommend SSD enough, you will never go back. SSD also makes much more sense in a car due to the environment its in, especially with a lowered G!
I use the M4 from logic for PSU and love it. Never had any battery issues putting the computer into hibernation when I shutoff the car either. It is a DD though. Nice that same apps remain open next time you turn on the car although Osiris CIPHER will quit responding and freeze out on next boot everytime because it hasnt gone through the init process with the ecu. win7 quickly catches it though and I kill it and hit the shortcut real quick again.
I had to remain on 32 bit version of 7 due to a limited driver ability for the finger print scanner built into the driverside door panel so I am maxed out at 4gb ram but luckily nothing I run is too intensive.
