Samsung Galaxy Tab 2 7inch tablet in 2006 double din
Old Dec 26, 2012 | 07:47 PM
  #46
viceversa's Avatar
Really isnt that much to it! Just helped out with another install for guy down here in San Diego with a WRX. Same tablet and everything, turned out great.
Old Mar 12, 2013 | 12:33 PM
  #47
pololance's Avatar
I know this is a little resurrected, but I've been debating between a Tablet install or a full-out CarPC install.
Is your Alpine sub installed, and how does it sound?
What was your solution for bluetooth hands-free?
Old Oct 8, 2013 | 03:28 PM
  #48
Play123boi's Avatar
Ok you setup is SICK! I might have to try this with mt Lexus! Do you get obd2 info?
Old Oct 8, 2013 | 03:30 PM
  #49
Play123boi's Avatar
Originally Posted by viceversa
I was very surprised with how readable the screen is even in the middle of the day... The screen on the tablet can get very bright and I've never had a problem reading the screen.
Do you worry about moisture or if it gets cold?
Old Oct 8, 2013 | 03:32 PM
  #50
Play123boi's Avatar
Haha randy haters gonna hate. Bluetooth and audio inputs will be solved with the eq. And radio... Not exactly a critical function for me. If I really wanted radio I would've bought a tablet with a built in radio receiver which they do make in case anyone else is wondering.
Use Tune in radio its free and has local stations
Old Oct 8, 2013 | 06:13 PM
  #51
viceversa's Avatar
thanks! and yup using the torque app
nope. only thing I worried about was heat in the summer. When I do it again it will be a setup which can be easily removed so i can take the tablet with me.
Old Oct 15, 2013 | 09:48 PM
  #52
radi4fun's Avatar
Hey man, I was wondering of doing something like this. I have Pioneer AVH-7500DVD with Infinity BassLink that crapped out on me. It won't read CD's anymore and instead of buying a new head unit, I was thinking of just getting one of the Samsung Tabs that are much cheaper than compared to a new headunit.
I already have a double din dash kit so all i would have to buy is a tablet. What are your thoughts on the new Samsung Galaxy Tab 3 or the Nexus 7? Would either of this work fine? Also you wanted to make the tablet removable/ detachable. how are you planning on doing this? I would love to watch you do this so i can do it on my own car.
Old Oct 15, 2013 | 10:06 PM
  #53
Urbanengineer's Avatar
I am envious. I opted out and went with Pioneer's AppRadio, because it relays my iPhone's screen and is a little simpler to use. GREAT WORK!
Old Oct 16, 2013 | 01:09 AM
  #54
Killerzracing03's Avatar
Id like to suggest two options if you plan on going this route. A DSP (digital Signal processor)
JBL MS8 (powered too not the strongest 20x6 or 7 irrc @ 4ohms 30@2)
http://www.sonicelectronix.com/item_...SearchClickout[query_id]=2459750&SearchClickout[Ignore]=1
Only needs 2 rca's to make to make a surround system and tunes, and adjust time alignments and alot more.
Mini DSP
http://www.minidsp.com/
There are alot more DSP's to buy but these are the best values IMHO.
I didnt look into the MS8 until now. I knew about it but the fact its powered is awesome, or it could be bypassed to an external amp.
Old Oct 8, 2014 | 12:27 AM
  #55
eswift1983's Avatar
sorry for the bump but I was wondering if you ever looked into mounting it in the cubby? When the door is open there is a 3 inch flat spot that i feel it would mount to easily and with perhaps a little modification you could just close the cubby and PRESTO stock look...since it's attached to the cubby door and all.. just a thought.
I have done some measurements and the tab 2 7.0 should fit?
Kelvin Style006
May 23, 2016 03:47 AM
alessandro
Oct 8, 2015 09:29 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
Vanessarino
Sep 12, 2015 10:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
