Car Battery replacement - watching dvds
Old May 1, 2006 | 07:18 PM
twantrd's Avatar
Hi guys,
Since I purchased the StreetDeck bundle and it has the option to watch DVD's, should I invest in a different car battery? I mean, sometimes I would like to watch dvd's in a parking garage while waiting for my girlfriend to finish her shopping . What car battery should I go for? If it's not necessary to buy a new one, should I just get a battery jumper kit? If so, which one works well? Thanks.
-twantrd
Old May 1, 2006 | 07:36 PM
GLuXuRy's Avatar
optima?
Old May 3, 2006 | 10:38 PM
dwoloz's Avatar
Youd be best getting a 2nd deep cycle battery and a battery isolator an keeping your stock battery for just starting the car
Ive heard Walmart has some pretty reasonably priced deep cycle batteries
Old May 7, 2006 | 11:36 AM
BigSash's Avatar
yes get an Optima Yellow Top D35 to replace your Stock OEM battery
Trust me that is the battery you want. either that or an Optima Yellow Top D51R. but the D35 will give the most power and is deep cycle hold on I will find some links...
Old May 7, 2006 | 11:38 AM
BigSash's Avatar
here is a thread from the sedan in which these battery options are discussed batteries are the same for coupe/sedan.
https://g35driver.com/forums/showthr...llow+top+sedan
and here is a good sight with optima batteries for purchase or for your own further research
Old May 8, 2006 | 04:24 PM
twantrd's Avatar
Ahh awesome, just the info I needed. Thanks!
-twantrd
Old May 8, 2006 | 04:33 PM
BigSash's Avatar
whoops that is the wrong link for the second one it should be http://www.1st-optima-batteries.com/
Old May 12, 2006 | 04:50 PM
rcdash's Avatar
D51R is smaller but can hold juice for about an hour running carPC but with AMPS off. In standby mode, while still powering USB devices, it lasted me about 2 days before not being able to crank. I just set my cutoff threshold higher on my CarNetix P1900 and all has been well (11.25 V cutoff instead of 10.6V).
chinee
Jun 10, 2024 07:48 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
Karnicle
Jul 23, 2015 05:08 AM
SIKKI
Jul 21, 2015 01:55 PM
