Bird Mishap Need!
Originally Posted by highside107
Dang.. leaving bird poop on the car that long will definitely eat away at your clearcoat
but this just happened to me today! i left it on there no longer than 8 hours!
Unfortunately bird dropping can etch into the clear coat in just a few minutes. What basically happens is that they eat away at a small portion of your clear coat and it can leave a "ring" like shape in the clear coat. You can see this ring in direct sunlight or under florescent lighting. To get rid of this you will most likely need a good two step polish. The first polish is a medium cutting polish (like the Poorboy's World SSR 2.5, Menzerna Intensive Polish) that will smooth out the clear coat. Then follow it up with a light cutting polish (Poorboy's World SSR 1.0, Menzerna Final Polish II) to make sure the surface is nice and glossy again and optically clear. A buffer will help but it can be done by hand as well. Clay bar will not remove these marks but only help remove any contamination left behind. Waxes will only cover these marks not actually fix them and cleaner waxes are really just light polishes which will help but is probably not cutting enough.
Hope this helps!
Hope this helps!
i dont have a wring
its a yellow with hint of green stain about .25" x .25"
its small but i hate it! its on my trunk and very noticeable! probably only to me though..but still!
Originally Posted by ivoryWisp
wow, you're extremely accurate. i had the EXACT same stain on my IP.. and i tried a bunch of crap and couldnt get it off, and then in 2 days.. it dissappeared. MIRACLE!
I've heard this before from seasoned pros, too.
The basic logic behind it is that the sun's UV rays bleach/bake the stain out. It's really only observed on white vehicles, but is pretty neat.
One of the few times the sun will work to your advantage when detailing
FS[NorCal]: Covercraft Evolution Custom Fit Car Cover
rsingerG35
Accessories
Mar 16, 2016 01:41 PM
Finiti35
Florida G Club
165
May 3, 2011 08:40 PM
Eurog35
Mar 12, 2005 05:08 AM
