Necessary to clay before polishing/compounding?
Old Sep 13, 2006 | 04:23 PM
scorcher76's Avatar
As the title says, is it necessary to clay the paint before performing any compounding or polishing?
Alex
Old Sep 13, 2006 | 04:33 PM
Alan's Avatar
yes. you want the surface as clean as possible.
Old Sep 13, 2006 | 05:43 PM
LMG_35C's Avatar
If your talking about machine compounding and/or polishing, (compounding indicates serious paint removal), it wouldn't be necessary.
If being done by hand, then I would certainly agree it's the best way to get the surface contaminants removed BUT it's always suggested that you use the least aggressive method first to see if you can get the desired result. You want to remove the least amount of your finish that necessary..
- cleaner wax (very light polish)
- clay
- polish
- compound
- wet-sand
Old Sep 13, 2006 | 05:48 PM
gary c's Avatar
Your better off..............
Yea, as long as your taking the time to polish your
G you may as well do it right the first time. Claying
will remove the crud on your paints surface. Now you can wash, clean and wax your car for a complete
job.......don't forget the tires.
Old Sep 14, 2006 | 09:21 AM
scorcher76's Avatar
Clay...
- clay
- polish
- compound
- wet-sand
Yes, I will be using the Porter Cable for polishing. So as you suggested, I will skip the claying .
Thanks for your info.
Alex
Old Sep 14, 2006 | 09:25 AM
G35stilez's Avatar
Concours d'Elegance
Yes.
Even on new cars, contaminants find a funny way of latching onto the surface.
Clay will *pull* the brake dust, rail dust, IFO, rust dots, tree sap, and other harmful contaminants from your surface.
IMO, it is a quintessential step in detailing.
Old Sep 14, 2006 | 11:19 AM
scorcher76's Avatar
Clay
Originally Posted by G35stilez
Yes.
I will clay then polish! Give you guys results later tonight with pictures!
Alex
Old Sep 14, 2006 | 01:22 PM
Picus's Avatar
Staff ALUMNI
I'm sure Sean meant this, but just fwiw clay doesn't pull anything. It abrades anything above the layer of the paint.
But yes, it is definitely a step you want to keep in, imo. If you are polishing often you can skip it; however claying once/twice a year is always a good idea.
cmesidewayz
Sep 29, 2015 09:28 PM
CKwik
Sep 9, 2004 10:09 AM
Premier
May 18, 2004 05:09 AM
rca
Apr 26, 2004 06:26 PM
