cleaning 3 piece wheels
Old Nov 17, 2006 | 02:18 PM
Fiveseven's Avatar
i have 3 piece iforged wheels and im having a hard time cleaning the area between the center piece and lip.. there seems to be grime there that just wont go away... what do you guys use?
Old Nov 17, 2006 | 02:26 PM
G35SHAWN's Avatar
I go through the same problem with my Work Meister. Usually it takes just over 30 minutes to clean each wheels. Usually i use Q-Tips for those hard to reach areas.
Old Nov 17, 2006 | 02:28 PM
Fiveseven's Avatar
my grime seems to be a solid rock :[ anyone else wanna chime in?
Old Nov 17, 2006 | 02:37 PM
kenchan's Avatar
Griots garage has a boar's hair brush to do wheels. you'll probably need to
agitate it a little with car soap and rinse off.
after its clean, i only use QD (Prima Slick) to remove brake dust.
Old Nov 17, 2006 | 02:55 PM
Fiveseven's Avatar
ahhh.. i dont think i can get any of those products here in cali
Old Nov 17, 2006 | 03:54 PM
Punchit's Avatar
I clean those tough to reach areas with the P12S Metal Polishing Soap. It comes with a sponge and you just get it wet and wipe on the soap. It instantly has a rich lather that cleans the wheels and leaves a great shine too. For any really stuborn stains I use the P21S Finish Restorer, probably the strongest metal polish that I've used. This process isn't exactly fast but it works really well and is faster than many other methods I've used.
Old Nov 17, 2006 | 03:59 PM
G352NV's Avatar
Never enough
Something that also works great is orange cleaner. I get it at home depot by the gallon. This is the best cleaner Ive ever used. I use it on EVERYTHING! For the house the cars everything. Its about 10.00 a gallon.
Old Nov 17, 2006 | 04:19 PM
VinNYCG's Avatar
G SQUAD
thats not the same as orange oil is it? You used that on your black asantis?
-Vin
Old Nov 17, 2006 | 05:58 PM
G352NV's Avatar
Never enough
Well cant say Ive used on on the Asanti's. They havent been dirty enough. But Ive used it on other wheels. It wont hurt them. It the SHIET!
Old Nov 17, 2006 | 06:16 PM
Fiveseven's Avatar
i dont think imma use the orange oil... punchit is there a local shop i can purchase those?
Old Nov 17, 2006 | 06:28 PM
G352NV's Avatar
Never enough
Hahaha cool.
Old Nov 18, 2006 | 09:18 AM
kenchan's Avatar
really?
www.griotsgarage.com
Old Nov 18, 2006 | 02:46 PM
nosey's Avatar
a soft tooth brush or maybe something softer should work..easier than a q tip
Old Nov 18, 2006 | 07:48 PM
kenchan's Avatar
like boar's hair brush...
i wouldn't recommend using toothbrushes unless they are similar
hair. most nylon brushes will scratch.
Old Nov 19, 2006 | 01:57 AM
redlude97's Avatar
Yes, boar's hair is the way to go, search on autopia and its recommended quite a bit
