Hazy Clear Bra???
Old Nov 30, 2006 | 11:09 PM
nm3th's Avatar
Hazy Clear Bra???
Just wondering, what does everyone use to get rid of the haze on a clear bra?
I've had my car almost a year now and a clear bra for just as long. The bra is still in good shape... only a couple of dings here and there. I just don't like the fact that the clear bra is a lot more visible now because of the hazing.
I was thinking of using 3M plastic polish and cleaner, but would like to see what everyone else uses.
Old Nov 30, 2006 | 11:43 PM
ttrank's Avatar
Grocery getter
Have not had a problem with mine yet. I would look on the 3M site and see what you can find.
Old Dec 1, 2006 | 12:07 AM
Punchit's Avatar
Can you post a picture? I know this is probably hard to tell but does the haze seem to on top of the clear coat or beneath it?
Old Dec 1, 2006 | 12:33 AM
nm3th's Avatar
I don't have any pics of the haze right now. The haze appears to be on the top surface of the bra.
I had the bra put on a day after I picked up the car off the lot. BTW color is black.
Old Dec 1, 2006 | 07:41 AM
GTScott's Avatar
I would try Plexus or a similar light plastic polish/wax. If that does not touch it, it is most likely not on top. If that is the case, it may be a warranty issue with the film.
Mine has been on for one year in January, 2300 miles, and is just as clear as when it was new.
-GT
Old Dec 1, 2006 | 11:39 AM
Punchit's Avatar
Plexus is a great plastic cleaner, you could also probably try the Klasse AIO.
Old Dec 1, 2006 | 01:59 PM
Paragon's Avatar
I used Menzerna Final Polish II with a Porter Cable. Made it look like new...then finish off with Klasse AIO and Zaino.
Old Dec 1, 2006 | 07:59 PM
Z2G's Avatar
Z2G
If you had it professionally done, you may want to check with the installer for warranty details. I am certain that every manufacturer of "clearbra" film has some kind of warranty. If I'm correct, most carry a 2-3 yr warranty or longer.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
