removing touch up paint..help!
Old Feb 12, 2007 | 10:12 PM
diablo1356's Avatar
anyone here know how to remove touch up paint?? i think i did a ****ty job with the touch up paint and i gave it some time to set...like 2 hours. it wasnt done properly so i tried to take it off with some alcohol but no luck..just a crappier job. so i decided to just brush somemore touch up paint over the scratch and to just let it set, then clear coat it, then wet sand the area and hopefully it will look ok. so its setting right now over night, but i really wanna just start over. any ideas?? if i dont like the ultimate job can i remove the touch up paint? thanks for all the help in advance!
Old Feb 12, 2007 | 10:32 PM
Picus's Avatar
Staff ALUMNI
If it's only been sitting for a few hours a decent solvent should remove it. Was the rubbing alcohol you used diluted? It should dissolve it. If not you can try mineral spirits. If that doesn't do it lacquer thinner will.
Old Feb 12, 2007 | 10:34 PM
diablo1356's Avatar
so this rubbing alcohol/mineral spirits/lacquer thinner wont ruin the other paint? its been sitting now for about 7 hrs.
Old Feb 12, 2007 | 10:35 PM
DHCrocks's Avatar
lanka will remove the excess paint.
www.langka.com
Old Feb 12, 2007 | 10:38 PM
diablo1356's Avatar
wet sanding should to shouldnt it?
Old Feb 12, 2007 | 10:45 PM
DHCrocks's Avatar
yeah you can wet sand but it's dangerous. Too much and you'll bust thru the clearcoat and dull the finish or worse yet burn the paint and you'll be left with a dark spot.
Old Feb 12, 2007 | 10:46 PM
diablo1356's Avatar
can you get a glod eliminator locally...like from a pep boys? i know langka is not the only company that has a product like that
Old Feb 12, 2007 | 11:26 PM
diablo1356's Avatar
bump
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
