Question - Zaino Z5
Re: Question - Zaino Z5
Yes Z-5 will do a great job of covering fine scratches. What I do is put on 2 coats of Z-5 let it cure overnight, and then put on 2 coats of Z-2 to finish.
If you're in a cold climate, you'll need the ZFX cure accelerator to succeed.
GSM
<font color=red>G</font color=red>S<font color=green>M</font color=green> <font color=black>Silverstone Coupe</font color=black>
GSM
Yes you can use Z-5 by itself. The Z-2 will just deepen the shine, but you don't have to use it.
The ZFX is an accelerator which you'll need for the Z-5 to cure and dry if it's cold.
No need for Z-1.
GSM
No need for Z-1.
GSM
so wait, after you apply 2 coats of z-5, you put 2 more coats on top of the z-5 without buffing the old z-5?
2003 G35 Coupe 6mt Diamond Graphite
1992 Jeep Cherokee Blk 5.5 RE lift /w 33s
AIM= bkchang79
AIM= bkchang79
No bro. You apply one coat of Z-5 and once it's dry, buff if off. In between coats it's wise to apply Z-6 to keep things clean. Then another coat of Z-5 then Z-6.
Next day, do the same with Z-2 (and Z-6).
Don't forget the wheels. It helps keep the dist off them.
GSM
GSM
all I have ever read specifies that you need to use other the ZFX or the Z-1. The polish lok chemically reacts witht eh Z-5 to produce it's hard shine. Here is a link to zaino's website. http://www.zainostore.com/Merchant2/...de=APPLICATION You might be able to use the Z-5 alone but your not getting the best effect by skiping the Z-1 or zfx
Jim
'03 Sedan
Brilliant Silver/Graphite
6MT/ Premium package
Sport tuned suspension
Aerodynamic Body Kit
Navigation and Satellite Radio
Jim
'03 Sedan
Have you considered using the Z1, Z2/3, Z5 combination in place of the carnauba wax? To each his own, but IMO the Zaino is easier and faster than wax. Plus, it gives a better shine. Wax physically bonds with paint. Zaino chemically bonds with the paint.
2K4 G35S 6MT, Diamond Graphite/Graphite, Premium Pkg
2K2 GS300 5AT SportDesign, Millenium Silver/Black
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
