Plastic Bag melted on exhaust pipes
Old Mar 4, 2007 | 08:58 PM
jonnylaw's Avatar
So I'm crusing and one of those plastic sheets that is used for dry cleaning goes underneath my car--look in the rearview and doesn't come out. Get home and the plastic is melted to the pipes w/ the logo from the cleaners and all--It reaks wicked bad of burn plastic--I got some of the plastic that wasn't melted--but the rest is now melted on the pipes.
Does anyone know the best and safest way to clean/get the melted plastic off the pipes? Anyone know if this condition will cause any other harm besides bad smell? Anyone have a similar incident? Thx for the input!
Old Mar 4, 2007 | 10:25 PM
Vegas79's Avatar
Same thing happened to me. I couldn't even scrape the melted plastic off. I ended up letting it burn away. Took about a month for the smell to disappear.
Old Mar 4, 2007 | 10:29 PM
papiloco21's Avatar
haha same to me too....left it for a week....got fed up with smell...jacked car up and scraped off with a large flathead screwdriver.....in hindsight, much easier to use a chisel.
Old Mar 4, 2007 | 10:43 PM
k_hojnacki's Avatar
same thing here, got hung on my midpipe, I took it off and wire wheeled it off.
Old Mar 4, 2007 | 11:22 PM
jonnylaw's Avatar
So should I use this experience to order the nismo jdm weldina exhaust I've been wanting to order for some time now
Old Mar 5, 2007 | 03:06 PM
Otacon132's Avatar
doooooo it
Old Mar 5, 2007 | 05:27 PM
kenchan's Avatar
i hate it when that happens. lol...
i used a window scraper (razor blade with handle) and a chizzle and
gently scraped most of it off, finished off with a sanding block (400grit)
and polished at the end. i can't stand that melted plastic smell.
Old Mar 5, 2007 | 06:54 PM
Andy2434's Avatar
LOL . . . That happened to me soon after I had installed my HKS. I used denatured alcohol and stainless steel cleaner to remove the mess. Fortunatley for me, the mess wasn't on for long prior to the removal.
Old Mar 5, 2007 | 07:04 PM
Hi-TechG35's Avatar
Damn that sucks. When I see plastic on a street (not the highway) I pull over and let it go by first...lol
Old Mar 5, 2007 | 07:39 PM
jonnylaw's Avatar
Thx for the input all. I'm glad to know I haven't been the only one to ride around w/ burnt plastic smell. So it seems, scraping off the plastic once cooled, then using a wirewheel or polisher to get off the rest is the way to go as opposed to power washing or the like? I assume there are some sensors down under there as well that would need care to not be damaged?
And I bit the bullet and ordered the jdm weldina exhaust, which I should get in 14-21 days via japanparts.com. Can't wait--I'll post flicks, sound clips, impressions when I get it and put it on--I just got to be sure to avoid these pesty plastic pieces of **** flying around on roads.
Old Mar 6, 2007 | 11:12 PM
Down_Shift's Avatar
jack up the car----------- get a steel brush and brush it off while the plastic is still hot... I had to do it on my RSX before.
Old Mar 8, 2007 | 04:44 PM
jonnylaw's Avatar
So I took it to a friend of mine who is a service advisor at my dealership. We took a look under the car. Luckily no plastic was melted on any of the 02 sensors or cats. The melted plastic was on both sides of the stock cover over the y pipe. A tech takes a smell, goes and gets these huge canisters w/ a torch on the end and torches the plastic right off!! The plastic is almost all off, w/ a little residue of smell--but I guess flamethrowing the plastic is another option!
Old Nov 28, 2007 | 01:57 PM
Monzo's Avatar
Yeah this just happen to me today. How long is too long to wait before scraping the plastic off. I should be good if I get to it by the weekend right?
Sorry had to rant, stupid garbage!
Old Nov 28, 2007 | 03:42 PM
kenchan's Avatar
you can pretty much scrape it any time...but as it gets old it gets harder
to remove completely so earlier the better.
i dont like the heated pipe way cause the plastic gunk stretches and sticks
to my window scraper. i just did it while the pipes were cool to the touch.
be careful when jacking up your car or while you're under there. make sure
you chock a tire if you're going to use ramps like me.
