Clay bars for first timers
Old Mar 14, 2007 | 08:59 PM
G35-2-B's Avatar
The 145 clay bar that is available at carcaresmart dot com - is that a good choice for begniners....or is that one of the more agressive clay bars?
Old Mar 14, 2007 | 09:25 PM
redlude97's Avatar
Never seen it before, but if its your first time, just go and pick up a claymagic/meguiar's/mother's clay bar kit from the local auto store. Any one of these will work fine
Old Mar 15, 2007 | 04:15 PM
Sergei's Avatar
Zaino's Z-18 clay gave me excellent results in removing rail dust (after initial purchase my '06 G35 was full of this stuff), tree sap and some overspray from a wheel repair job. Make sure to always lube with Z6 or Z7 (wash soap diluted with distilled water). No mars or scratches, and make sure to gently rub over the paint.
Old Mar 15, 2007 | 05:58 PM
Nismo G's Avatar
Clay bars are clay bars, you just have to know how to use it.
-sean
Old Mar 15, 2007 | 06:01 PM
redlude97's Avatar
-sean
Not exactly, clay bars come in different levels of abbrasiveness, and some will cause marring on a surface
Old Mar 15, 2007 | 06:03 PM
Nismo G's Avatar
Tru, i dont think anyone on here needs one of those unless they have been offroading in the G IMO.
-sean
Old Mar 15, 2007 | 06:23 PM
redlude97's Avatar
I have 1, works great and much faster on the lower body panels when you know you are going to polish anyways
Old Mar 18, 2007 | 08:09 AM
lelg35's Avatar
I have a related question on clay bars. I'll be using it for the first time this spring - I'll practice on my beater before I do it on my G. But, I read many posts on how to use it: wash, claybar, etc, etc.
But, I see a lot of inconsistencies on whether we should wash the car after using the clay bar. Some members say to wash after using the clay bar, others say to go directly into polish/wax.
What's everyone's opinion? Do we need to wash the car after using the clay bar? Or can we go straight into polish/wax?
Old Mar 18, 2007 | 08:19 AM
BadBoy06's Avatar
-sean
in most cases thats correct
Old Mar 18, 2007 | 10:49 AM
G35-2-B's Avatar
-sean
..but the point is they need to know what type of clay bar they are using. These things are not excalty labelled well. I have one, but dont really know if its mild, abrasive etc.
From what I read, i believe the rule of thumb is that white/grey is mild....and red/blue is abrasive.
Old Mar 18, 2007 | 11:15 AM
DieselCasa's Avatar
DCASA
I just picked up mothers clay bar kit this morning at advanced auto. Someone posted you need to know HOW to use it. Any tips / advice? or should u just follow the directions?
Old Mar 18, 2007 | 11:32 AM
Nismo G's Avatar
I used the mothers clay bar, it was gold. Did a great job..i cant see anyone needing more than that unless their car gets abused pretty hard by outside contaiminents.
-sean
Old Mar 18, 2007 | 11:53 AM
O NO's Avatar
Staff ALUMNI
Over the years here there have been tons of threads on claybar.
You know the drill.........
Search is your friend....lol
Old Mar 18, 2007 | 12:11 PM
gary c's Avatar
Clay Bars and how toooooooo!
One key in using the clay bar is to use lots of lube/spray so the clay moves
without draging.......follow the body line when using it.......run your hands
over the surface so you know the particulates are gone......then wash your
car completely. You don't want to add your wax to anything left on your
painted surface. Good Luck.......have fun!
Old Mar 19, 2007 | 01:21 AM
redlude97's Avatar
Except Sonus's aggressive block claybar is grey, and clay magic's mild clay is blue, so two of the most popular clays out there already don't follow that rule. Best way to know is just to be sure you know what you are buying, and keep stuff labeled.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
NyCrAzY
Oct 1, 2015 09:19 AM
