Ask a Professional Detailer...
#496
i feel like i ruined my claybar.... heres why. I used a ziploc to hold it in andi took it out today and most of it was sticking to the ziploc, but i got a good chunk out so i figured whatever, then i put it on my wet car and the clay kept sticking to the paint, what did i do wrong? or is the clay bar done with? how do i keep it?
#497
Was it just water you were using the clay bar on? Or did you mix it with some shampoo?
George
#498
on
hello, yea i just had a couple questions.
I put touch up paint on my body and now it's kinda clashes, i was wondering is there anyways i could blend it without havin to repaint the whole bumper.
second questions is i took out the door molding and since it was cold the edge of the modling didn't come off properly and it looks like the adhesive scorched the clear coat of the car. i tries wetsandin a tad and buffin it and it looks like it helps but is there any product i could use to help blend it/fade it.
Thanks,
-Rogue
Thanks,
-Rogue
#499
George,
I have a set of wheels I want to get cleaned and polished up real nice. They are already in very good condition, but I want to make then look the best I can. I have removed them from the car, sprayed down with P21S wheel cleaner then washed with Gold Class wash. Now I am ready for the next step.
Let me give you some details on the wheels. They are one piece cast aluminum with a gray/silver painted center, polished lip, and clear coated.
I have some Never Dull metal polish, but not sure if I should use this on clear coated lip. I also have some Wheel Wax for protection.
Should I just use a good clear coat car polish followed up by two coats of the Wheel Wax? What process do you recommend?
Thanks.
Thanks.
#500
When you used the touch up paint, did you wet sand it down to the same level, the polish away the wet sanding marks? This usually will help blend it. Another trick is to mix some clear coat in with the colored paint. This usually helps with metallic colored paint as it can be quite difficult to match perfectly.
Thanks,
-Rogue
Thanks,
-Rogue
Originally Posted by DRG35R
George,
Thanks.
Thanks.
2 thin applications of Wheel Wax will work great after polishing. After that, regular maintenance with just automotive shampoo and water should do the trick until either the Wheel Wax needs reapplication or you want to do the entire process over again.
Good luck, keep us posted on how things turn out.
George
#501
Then I'd suggest following up with a very mild polish to really restore the finish. Keep in mind, wheel clear coats are typically not as strong as the one on your paint so be careful with how much pressure you apply and how strong of a polish you use.
George[/QUOTE]
ScratchX mild enough?
George[/QUOTE]
#502
Originally Posted by Texasscout
Question about "wheel rash". I have some curb rash right on the edge of my factory powder coated rims. Could I sand that out and repaint just the rim edge? I have tried to contact a profesional here in South Texas with no luck.
http://www.audiworld.com/tech/ext43.shtml
I think the only thing that may change is the color to match your wheels. Good luck, let us know if you give it a shot and how things turn out.
George
#504
Finally got my PC and used it over the weekend, that thing is amazing. Took off all the flaking in my headlights and my car looks like a mirror. The outside of my wifes car doesn't look bad either, now if you guys can make something to keep her from throwing crap in it all day that would be great.
#505
![Stick Out Tongue](https://g35driver.com/forums/images/smilies/tongue.gif)
#506
Originally Posted by Detailed Image
I don't have much experience correcting wheel rash, but here's the best writeup I could find on the subject.
George
George
#507
George,
with regard to my wheel polishing and protecting. the ScratchX worked great and the wheels looked very clean and shiny after application. guess I should have know this since it works so well on painted surfaces. thanks for the product suggestion.
the Wheel Wax is another story. application was easy enough, but if you let this stuff sit, it is difficult to remove. this is a PITA with a wheel since I am doing all this work by hand. applied to the entire wheel and then went back to remove with MF towel. came off easy enough at first, but as I moved along it became difficult, especially in the crevices and lug holes. obviously you can not move as fast removing product from a wheel as you can a body panel.
should I just use another sealant product like Synwax or NXT which is easy to remove? will something like these hold up as well as a specific product like Wheel Wax?
any suggestions or can you recommend a more user friendly product? how about that Poorboy's wheel sealant?
#508
Wheel Wax & Poorboy's Wheel Sealant are designed specifically to withstand some of the higher temps that brakes can produce. This, combined with their slick surface left behind makes them a better alternative than most sealants.
Personally, I have access to both Wheel Wax and the Poorboy's Wheel Sealant and I don't have to think for a second to grab a jar of Poorboy's Wheel Sealant. I feel that it is a superior product, works on more surfaces, and is easier to work with. I have yet to come in contact with someone who said this product did not meet up to their standards. I'd say we sell the Wheel Sealant 12:1 over Wheel Wax.
In general if any product starts to become difficult to remove, try misting your towel with a quick detailer solution or some distilled water. This will usually aid in product removal.
Hope this helps.
George
#509
George,
Can you post a pic of your wheels before and after if you have some?
I plan on doing the same thing to my wheels.
(detailed image)
I have axis shines on my car and I want my lip to stand out more since they are machine polished.
Do you have any suggestions on what I can do?
I want them to stand out like my old wheels in the last pic or close to it.
Thanks
#510
on
George,
