Ask a Professional Detailer...
#346
Hi George,
What is the purpose of the P21S Paintwork Cleanser? Does it replace washing with dawn or using isopropyl alcohol to remove old wax and sealant? Does it act as a finishing polish?
Also what is the best way to apply the Natty's paste wax since it is a bit hard to get my microfiber round applicator into that container?
#347
Originally Posted by erdog
Hi George,
Regarding the applicator pad, bulky applicators can be difficult to work with especially in certain wax containers. I use a standard foam applicator pad because they tend to be more flexible than other types of applicators.
Regardless what applicator is used, less is more, I cannot stress this enough. A swipe or two across the paste wax is all that is needed for a panel or two. With all the Natty's waxes, I find that the best method is to apply a panel and remove it almost instantly. I've played around with applying the wax to the entire vehicle then removing and found that it can harden up quite quickly and removal can become difficult or needs to be aided with a quick detailer or some distilled water.
Let me know if this helps. Good hearing from you.
George
#348
Originally Posted by Detailed Image
osiris32, good question. You certainly can do without the products specifically for cleaning pads. You can substitute the foam conditioning brush with a medium bristle tooth brush and you can soak the pads in any type of degreaser, such as the Snappy Clean you mentioned.
The key to getting the most out of your pads is clean them immediately after using them. The longer you let the pads sit and let the product cake up, the harder it is to clean. Having clean pads is critical to maximizing your results with any detail.
You can spin the pads at a low speed while gently brushing the foam pads with the toothbrush. This will help remove loose product build up from the pad. Afterwards, I usually let them soak in a degreaser for 10 - 15 mins, wring them out, working the product out of the pad with your thumbs and fingers, let them re-soak one more time. When done, give them one more good wring and you want to let them air dry completely before storing them in labeled Ziploc bags so no contamination can get to them.
Hope this helps.
George
Hope this helps.
George
How ever the pads i got has the velcro backing, will wringing it out damage the velcro?
Thanks again
#349
#350
Originally Posted by osiris32
Thank you very much George.
Thanks again
Thanks again
Thanks for the info...I love the smell of the Natty's Red. A little fruity though...haha.
It just took me four hours to wash, clay, polish with P21S, FMJ, Natty's Red by hand. I was going to put on 2 layers of FMJ but I was too tired.
George
#351
How was the end result? Any pictures of your hard work? Natty's Red does smell very very strawberry, haha.
George
Edit:
Pics of my detail session posted.
4 hour hand detail: Wash with Meguire's, Clay with Mother's, Prep with P21S Paintwork Cleanser, Protect with FMJ and a coat of Natty's Red, Wheels protected with Poorboy's wheel sealant. Phew!!!
#353
I had that problem with the red. After doing my hood, fenders and front doors I found that one section at a time was easier.
#354
#356
Tim & erdog,
Thank you both for sharing your results, both vehicles look stunning! It's nice to see that Poorboy's Natty's Red Paste Wax looks great on both light and dark colored vehicles.
erdog - your white has a very nice glow to it that shows a lot of depth and gloss. This is often difficult to achieve on lighter colored vehicles, nice work!
Tim - the depth and reflection on your black car is mind boggling. It does look black chrome. Dare I ask how many hours you spent detailing your car? Amazing work!
Thank you both for sharing.
George
![Biggthumpup](https://g35driver.com/forums/images/smilies/biggthumpup.gif)
George
#357
Thank you. I was very happy with the results.
I spent about 4 hours on the wash/poilish/seal. Then a week later I washed, waxed, and polished/waxed the wheels which took another two hours.
I can't believe I didn't get a PC before. The results are soooo much better than anything I have ever been able to do by hand.
I have one side question for you. The two orange pads I used are recessed in (they have a dip or bowl shape) as where the other white, black and blue pads I have are flush. Is that because you need to use more pressure with the orange or was there something wrong with those?
Thanks,
Tim
#358
Thanks,
Tim
Thanks,
Tim
A PC 7424 is definitely a solid investment for any car enthusiast.
Thanks again for sharing pictures of your hard work. The wheels look stunning as well and really complete the detail.
George
#359
George
George
thanks.
#360
Tim - They are designed that way so you can provide more pressure along the outer part of the pad. When using the orange (or yellow variable contact pads), you want to apply the product along the edge of the pad. It helps provide more cutting ability to remove imperfections.
OK, that was what I did. I had just never seen that info before.
Thanks,
Tim
