Bird poop stain on my black G :(
Old Apr 9, 2007 | 09:18 PM
sahiwal007's Avatar
today i saw this bird poop stain on my New G35 coupe and im sure its a stain , how can i take it off? i tried cleaning it with water but no luck! and the car is brand new and it just ruins the car with that Big stain on the side! please help me... thanks
Old Apr 9, 2007 | 09:21 PM
izmir41500's Avatar
G35driver Addict
that sucks. must be etched into the clear coat. you can try claybar, scratchx, and wax. if that doesn't work you have to polish.
Old Apr 9, 2007 | 10:58 PM
jgrasty's Avatar
Been there, done that...
Hello, sahiwal007:
Same thing happened to me; here's how I fixed it:
https://g35driver.com/forums/care-detailing/144317-first-exterior-detailing.html
Regards,
Joey
Old Apr 9, 2007 | 11:50 PM
Detailed Image's Avatar
Nice write up on that bird etching removal jgrasty! You took the best approach possible, using the least aggressive method possible to get the job done. A lot of detailers would have jumped right into the SSR2.5 and removed more clear coat than was necessary.
Great pics of a nicely detailed G
George
Old Apr 9, 2007 | 11:55 PM
sahiwal007's Avatar
i dont really have the poorboy's products i dont even have a porter cable, is there any other way? and im taking my g35 to the dealer tommrow to install the spolier do you think they could help out?
Old Apr 10, 2007 | 12:06 AM
I would go with izmir41500's recommendation to go with Meguiars ScratchX which can be found at any local automotive store. This is a light abrasive polish that needs to be applied with some pressure to get results from it. Afterwards be sure to protect that area with your favorite sealant or wax.
I'd recommend doing the repair work yourself. If you take the time to do it properly yourself, you will more than likely do a much better job than the local dealership detailer, and it's significantly cheaper.
Let us know if you have any questions on anything.
George @ Detailed Image
Old Apr 10, 2007 | 12:27 AM
ttrank's Avatar
Grocery getter
Any way do get rid of a stain like this with Zaino?
Old Apr 10, 2007 | 12:34 AM
sahiwal007's Avatar
ill try scratch x , hope it works
Old Apr 10, 2007 | 12:36 AM
Queenskid24's Avatar
there arent too many dealerships who do good Prep work/detailing so i would suggest you took care of the problem yourself. Usually a dealer would just use some strong abrasive compound and remove your clear coat...i speak from experience working at 1 and seeing what goes on...
Old Apr 10, 2007 | 08:27 PM
sahiwal007's Avatar
i just tryed the scratch x but no luck it just ruins my new car.... am i applying the scratch x correctly? what is the correct way ?i did it by the directions, i wish the bird never pooped
Old Apr 10, 2007 | 08:48 PM
superchargedg's Avatar
you might have to do it multiple times and make sure you rub it in with pressure.if not you will have to polish it out.
Old Apr 10, 2007 | 08:58 PM
Yep, this is a fine polish that doesn't have much bite to it. I've read in some instances where people needed to apply upwards around 8 - 10 coats of it to effectively remove a scratch or other imperfection. What is it doing when you say it ruins your car?
This would be a great time to invest in a Porter Cable, the proper pads and some quality polishes!
Old Apr 10, 2007 | 11:15 PM
sahiwal007's Avatar
yea i looking to get a porter cable soon i just received my car 3 days ago, do you guys know how long do i wait till my first wash? and also i see alot of swirl marks in the sun what can i do to take them off, there not that many swirls but you could notice them in day light when upclose, and there also light swirls not harsh and by the way i have OB as the color.
thanks I appreciate the help
Old Apr 10, 2007 | 11:39 PM
Congratulations on the new purchase! You would be fine to give it your first wash as soon as you like. In fact you could give it a complete detail even on day 1. The vehicles paint is baked at the factory which gives the paint the fastest possible curing time. By the time you get the vehicle, the paint is fully cured and ready to be treated and protected.
I'd encourage you to read thru the Ask a Professional Detailer thread, as it covers a lot of great topics including specifically addressing swirled Obsidian Black paint.
If you have any questions on anything, please do not hesitate to ask.
Old Apr 13, 2007 | 10:46 PM
sahiwal007's Avatar
i tryed using scratch x but no improvment , what should i do now?
thanks
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
mbe32
Interior
Oct 1, 2015 09:47 AM
Vanessarino
Audio/Video/Electronics
Sep 12, 2015 10:48 AM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
