diy oil change w/o lift
Old Apr 15, 2007 | 05:19 AM
empfl's Avatar
just curious but can you diy oil change w/o a lift? jacking up the car is probably a must right? going to the dealer just for an oil change seems like bitch work specially since they take so long..
Old Apr 15, 2007 | 06:07 AM
gotyamahas's Avatar
they have some Pump type unit that,has a thin hose that goes into the dipstick tube to suck out the old oil..
Thats what they do for boat engines...
but, to change the filter ,you have to unbolt the splash shield under engine..
meaning , you have to get under the car ,somehow?? Rack?/or jack?
Old Apr 15, 2007 | 09:01 AM
kenchan's Avatar
i use a Rhino ramps and made my own extensions out of wood.
you have to raise it to get to the filter cause you need to remove
the bottom cover.
dont go under there with just your factory jack. those things can
fail at any second if you move the car even alittle bit.
Old Apr 15, 2007 | 09:53 AM
PRMax's Avatar
I made a DIY ramp with some wood I had laying around. Just made one for the right side of the vehicle.
Old Apr 15, 2007 | 11:34 AM
redwillow's Avatar
20 Year Member
i am using these lo pro ramp extensions with yellow steel ramps i bought locally.
http://www.griotsgarage.com/catalog....3030&SKU=10142
Old Apr 15, 2007 | 12:34 PM
Brando's Avatar
Cool
One of these:
http://www.lubricationspecialist.com...FSc8UAodWkwpAw
also makes it a lot easier and cleaner job!!
Old Apr 15, 2007 | 01:39 PM
kenchan's Avatar
kind of a copycat fumoto valve...
but the G is easy to do and really not messy at all.
Old Apr 15, 2007 | 05:23 PM
LT1 SS's Avatar
that is the fumoto valve, it has the logo on it and if read the bottom of the page it shows the fumoto warranty.
Old Apr 16, 2007 | 12:19 AM
Gordgee's Avatar
Administrator
Probably the easiest would be the Fumoto Valve and a remote mount oil filter kit. That way, just reach uner the car, flip the switch to drain the oil, and change the filter from inside your engine bay!
Old Apr 16, 2007 | 12:21 AM
kenchan's Avatar
just shows you that i dont use one. dont need it.
Old Apr 16, 2007 | 08:17 AM
Espresso's Avatar
Why are you guys suggesting all these valves and remote install filters just to change your freakin oil? All you need is a socket wrench, floor jack (stock jack will do), jack stand, & oil pan. Draining the oil should be a no brainer. For the under body cover, I remove the two screws holding down the corners and I'm able to reach in there and undo the oil filter by hand most of the time.
Old Apr 16, 2007 | 04:32 PM
canucklehead's Avatar
Originally Posted by Espresso
Why are you guys suggesting all these valves and remote install filters just to change your freakin oil? All you need is a socket wrench, floor jack (stock jack will do), jack stand, & oil pan. Draining the oil should be a no brainer...
I agree. We are talking about changing engine oil. I see no good reason to get carried away with mods for this basic maintenance item. Valves, remote filter locations...save the money and buy a set of stands. They are handy for many other purposes as well.
Old Apr 19, 2007 | 03:41 AM
Birdhouse's Avatar
It's Lonely At The Bottom
Thumbs up
Official Fumotovalve link:
http://www.fumotovalve.com/merchant.cfm?pid=162&step=4
and the DIY article:
http://www.g-owners.com/article_read.asp?id=26
Installing one is a great investment if you are into doing your own oil changes.
derres
Aug 28, 2015 03:27 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
