clear protective sheet in front of rear fender....
Old Sep 16, 2007 | 01:08 PM
noizedskyline's Avatar
I have a couple of question concerning the clear rear fender protection.
1. I got some dried wax stuck along the outer edges of the clear film. Any easy way to get them out other then using my finger nails, which i'm afraid might make creases on the paint.
2. Anyone decided to take them out, and was the fender more prone to rock chip?
(pic courtesy of Zombie's)
Old Sep 21, 2007 | 10:14 PM
Scrooge's Avatar
Yeah me too I was wondering if they were put the by the other owner. Are this good without the clear bra ???
Old Sep 21, 2007 | 10:20 PM
OSKIRE's Avatar
i have one side left....it's a bitz taking that sucker off.....
Old Sep 21, 2007 | 11:38 PM
MentalSpine's Avatar
use your good old toothbrush..
Old Sep 22, 2007 | 02:26 PM
ckp's Avatar
ckp
take a q-tip and some rubbing alcohol...that will do the trick.
Old Sep 22, 2007 | 08:09 PM
EvolutionGSR's Avatar
Your fingernail under some microfiber will do it too.
Old Sep 22, 2007 | 08:22 PM
kernel's Avatar
SEC > Big 12
i used a toothbrush as someone else mentioned, but i never though of using isopropyl alcohol on it, i guess I'll try that the next time it happens.
Old Sep 23, 2007 | 12:28 PM
Bobyl573's Avatar
does it really help with rock chips? i didn't even know that area has a higher chance to get hit with rocks than any other parts of the fender or the lower rear bumper area
Old Sep 24, 2007 | 04:30 PM
Scrooge's Avatar
Yeah why is it there ?
Old Sep 24, 2007 | 07:06 PM
kernel's Avatar
SEC > Big 12
cuz it looks baller
jk, i have no idea.
Old Sep 24, 2007 | 09:55 PM
kenchan's Avatar
ive had to replace mine (lower one) on the driver side from a larger rock
or branch tearing at it. so yah, it does provide protection. my paint was
not damaged under there. i also see a lot of speckles on the upper
bra which is evidence that debris is hitting it.
as far as removing the dried wax use your QD and MF towel. if you
use rubbing alcohol it will remove it, but it will also remove the wax
adjacent to the clearbra...
Old Sep 25, 2007 | 10:04 AM
Cassman's Avatar
Yes, it provides a ton of protection. I have 70k miles on mine and you should see how marked up that film is. Without it, I would have absolutely no paint in that area. Do not take it off. Just learn how to wax in that area.
Look at your car and think about it: That area is completely unprotected from stuff coming from the front area of the car. It sticks out due to the aggressive styling.
Th611
Oct 27, 2015 03:48 PM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
