Claybar the rims?
Old Sep 16, 2007 | 06:55 PM
donot521's Avatar
Claybar the rims?
I have Volk rims on my G and I am just wondering if I can claybar the lip?
I've heard YES but also NO (Might damage the clear coat)
so can I claybar the lip or not?
and is it safe to use car wax to wax the rims?
Thanks for the help!!!!!
Old Sep 16, 2007 | 07:00 PM
BayAreaRefuGz's Avatar
i fly low
claybaring the rims may also apply (correct me if i'm wrong) to body paint. both have clear coat. if you claybar without the appropriate claybar wax, you may remove a large amount of clearcoat. in other words, i believe it is safe and just dont over clay it. maybe 4-5 swipes shall do the trick.
-jeff
Old Sep 16, 2007 | 09:27 PM
kernel's Avatar
SEC > Big 12
if you do, just make sure you use enough lube, just as you should when you clay the body.
Old Sep 16, 2007 | 10:00 PM
kyu1021's Avatar
it's safe on the anodized lips. i had a slight haze to my volks and it took it right out. don't forget the lube
Old Sep 16, 2007 | 11:09 PM
kenchan's Avatar
griot's has very soft claybars that they claim will not even remove wax.
try that for delicate surfaces.
Old Sep 16, 2007 | 11:39 PM
kernel's Avatar
SEC > Big 12
maybe I am mistaken, but my understanding was that the purpose of a claybar is to remove contaminants & impurities like paint over spray, tar, sap, etc. Anything that is designed to remove this should definetely remove wax, if it's not then I would say that it is worthless.
Now if you're saying that it only should be used on delicate surfaces (like wheels) then that's another story, but I wouldn't use that and expect it to do what I wnated to on the actual body.
Those who are more knowledgeable please correct me if I'm wrong.
Old Sep 17, 2007 | 05:41 AM
redlude97's Avatar
Claybars work by shaving off contaminants in the surface that stick out past the paint with abrasives, depending on the size of the abrasives, they can themselves shave the top layer(ie wax). A very delicate claybar, which contains very fine abrasives, will not be able to shave very much off the top layer, which is why they work so slow on larger contaminants.
Doesn't matter either way, unless you are using an aggressive claybar, either a delicate or mild claybar will be safe for anodized wheels with enough lube, I've done some major decontamination work on some used wheels before, worked great
Old Sep 17, 2007 | 05:57 AM
Gfast's Avatar
wow i didn't know clay bar can used for wheel too.
just a quick question
i have a chrome wheel, and it have some dirt spot that i can't remove.
i wonder if the clay will do
and i already have a mother clay bar
will that work on my wheel?
thanks in advance.
Old Sep 17, 2007 | 09:29 AM
RBull's Avatar
Rated M
^try it and see.
No one will be able to answer that for you without seeing the dirt and knowing what you used etc.
-jeff
???? Giving information on something you know nothing about isn't helpful.
Old Sep 17, 2007 | 10:30 AM
kenchan's Avatar
as mentioned above, claybars are not all alike. some are course, some are
very gentle. griot's is a fail-safe system (their entire detailing stuff) so
you can use it on delicate paints.
the detailing tech at one of the details sessions said to me and everyone
there that their clay does not remove wax. from wat i can see, there is
wax remaining after using their claybar, but to how much? i dont know.
i usually wax after clay anyways.
Old Sep 17, 2007 | 11:38 AM
Cassman's Avatar
Originally Posted by RBull
^try it and see.
No kidding..???? Clay bar removing clear coat????
Old Sep 17, 2007 | 11:43 AM
gary c's Avatar
Claybar vs Chrome........?
thanks in advance.
I wouldn't! Chrome wheels use chrome cleaner/polish, that should take care
of your wheels!
Old Sep 17, 2007 | 11:49 AM
gary c's Avatar
Claybar vs Volk Rims..........?
Anything you get on those high dollar Volks should be removed with only
water/soap and only when the rims are cool. We've seen many members
mess up their rims my using detergents and related items that were too
harsh for the clearcoat. After they're clean it would be a good idea to
protect them with something like Wheelwax, that's what I use!
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
