GREAT tool for winter washers!!!
Old Mar 4, 2008 | 12:02 AM
  #31
Scrooge's Avatar
You also have to remeber that the foam gun has a detachable sprayer and the solution tank has a multi ratio stem incase you want to dilute the soap mixture. It also has a durable constructon, So you don't need to worry about it falling on the floor and breaking.
Old Mar 4, 2008 | 11:58 AM
  #32
Jeff92se's Avatar
Red Card Crew
Do you guys use the same amount of soap in the wash bucket when using this method?
Old Mar 4, 2008 | 02:02 PM
  #33
Scrooge's Avatar
I use 1:4 or 1:3 ratio of soap in my foam gun and a higher one for hyper concentrate soaps.
Old Mar 10, 2008 | 11:36 PM
  #34
ckp's Avatar
ckp
Where did you buy that googone window wash?? Wal-mart, target?? also did those few ounces of meg's gold and half full of water cover the entire car with foam??
thanks! plus good find!
Originally Posted by never gone
This is actually great year round. Most of the spider webbing and marring on peoples paint is from poor washing techniques. Here's a few tips to keep your rides looking great and lesson the chances of introducing or adding more swirl marks on your paint. It's really important this time of year if you're washing your car, you need to make sure you give it a good 3-4 minute soak first. Salt gets on our cars from driving around and then it dries. You have all these salt crystals that have now hardened on your paint and if you just spray your car down and start wiping with your wash mitt, you have a great chance of swirling the hell out of your paint. This is where the pre-soak is VERY important. There are a couple products like the foam cannon or the foam gun that are used to pre-soak a car. Only issue is they can be pretty pricey but I found a GREAT solution. Goo Gone makes a home window cleaning "gun" that you can spray your windows down, even on the second floor, and it's basically a bottle with their cleaning solution in it. I was out of the cleaning solution so I cleaned out the bottle and put a couple ounces of Megs gold in it, filled it half way with water, and started to soak the car. It worked extremely well and the best part is that it cost $7.99!!!! There are 3 settings on the nozzle: rinse, soap and off. Set it to soap and start the pre-soaking. Let your car soak for a good 3-4 minutes and I promis all the crap will come off a LOT easier and you have way less chance of scratching your paint up. Hope this helps.
Old Mar 11, 2008 | 12:56 AM
  #35
never gone's Avatar
I bought it at bed, bath & beyond. However you can get similar setups at home depot that are just for doing this kind of thing.
Old Mar 11, 2008 | 11:16 AM
  #36
darnelled's Avatar
I just use an empty, cleaned out bottle that I used for spraying lawn fertilizer.
Old Mar 11, 2008 | 11:35 AM
  #37
Wannabe6MT's Avatar
-MN G Crew-
I just go to a car wash in the winter (a GOOD one, not a gas station car wash)
Im not gonna freeze my *** off when its 10 degrees.
Old Mar 11, 2008 | 06:42 PM
  #38
uhohitzmikeo's Avatar
im glad i live in louisiana where the temperature barely goes below 50s. i even think its too cold outside to wash my car in the 40s-50s....LOL
Old Mar 11, 2008 | 11:00 PM
  #39
SVLRx's Avatar
I live in New Orleans also... And i've Hand washed my car just about every week to every other week since i bought it in July... It's never too cold to wash it over here, there's always a day that's calm or warm enough to do it...
Old Mar 12, 2008 | 10:34 AM
  #40
ckp's Avatar
ckp
i live in portland. and even in the winter i suck it up and wash it in the winter, lol. call me crazy but i love detailing my car!!
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
gatorglaze
Sep 10, 2015 12:03 PM
migurus
Sep 5, 2015 09:39 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
kevintandmd
Sep 3, 2015 06:41 PM
