Rim scuff, F$ck!
Old Mar 26, 2004 | 01:45 PM
Xman's Avatar
Rim scuff, F$ck!
Is there anything I can do with this? I just noticed them today. I haven't hit a curb or anything. Probably a rock on the road. I cleaned them out with denatured alcohol. Was gonna put a layer of Z5 on. Any suggestions? TIA
2K4 G35x/Brilliant Silver/Graphite/Premium/Wood
Stillen Hi-Flow/ Z tube/ Ground Kit
Old Mar 26, 2004 | 01:53 PM
fldrummer's Avatar
Re: Rim scuff, F$ck!
Pffff; that's nothing. You should see the scuff on mine from a curb I couldn't see (on that note, why do our headlights suck so much? I thought HIDs were supposed to be great!?)... Anyway, I've heard of some body shops that fix stuff like that, but I'm sure it's not cheap. I'll probably have to look into it eventually myself, since I'm leasing my baby and will have to have that fixed when the lease is up (d'ohhh!). Ask some body shops in the area if they do that kind of stuff or know of anyone else that does it. Either that or see if there is anyone on these boards or e-bay that has stock rims they want to get rid of. I'm sure there are some that got aftermarket rims and don't need their stockers anymore.
2004 6MT (Silver/Willow), premium & aero packages
My old ride (I still miss her; put a lot of pride and joy into it): http://www.n-body.net/registry/john95ga/
Old Mar 26, 2004 | 04:20 PM
g35girl's Avatar
Unimaginative, Indecisive User
that stinks. if repair is what you end up doing, then hmm. i don't know the details or the prices, but someone from the forum recommended this in one of their threads: http://www.fixrim.com/. good luck.
<font color=purple>.g35girl.</font color=purple>
Old Mar 26, 2004 | 06:22 PM
Britishbloke's Avatar
Same thing happened too mine on both passenger side wheels..much worse though, bloody wife took the car out and hit a curb. Anyway, talk too your local dealer, maybe they have somebody they use for repairs like this or can recommend somebody good.
Old Mar 26, 2004 | 07:05 PM
msGcar's Avatar
well, i keep telling folks, but apparently no one believes in such a simple fix: assuming that you have the stock alloy wheels and that paint damage is all you ned to fix, then go to walmart (or wherever) and pop $4 for a spray can of Dupli-Color High Performance Wheel Coating. it is an EXACT match. i had similar damage to my front wheel within my first week of ownership, stumbled on the paint and figuring i had nothing to lose gave it a try. i didn't do any sanding or prep work other that cleaning. just masked off tire, held can about 8 inches from spot and gave a quick burst then repeated times two, allowing about 15 minutes between coats. try it.
Old Mar 26, 2004 | 07:31 PM
Xman's Avatar
Thanks all,
I think I'll wait for a body shop until when/if I run a curb. Dupli-color huh? sounds like it worth a try. These are really minor but annoying. Sounds like it may do the trick.
Thanks again.
Old Mar 26, 2004 | 09:28 PM
KAHBOOM's Avatar
You can probrably get is fixed professionally for like $70
2003.5 5AT
Premium Package
Tire/Wheel Package
K&N Filter, Z-Tube, EGK
Old Mar 26, 2004 | 10:30 PM
GR8TG35's Avatar
Xman
I had a pretty good size curb rash on my front rim a while back, I was able to match the paint pretty well with a mix of Testors model paint....but the cuts were too deep to hide the damage completely....
I had a place by me fix my rim for around $100 but believe me my rim was a whole lot worse than yours....The coupe 18" rims are harder to match color wise...so I opted for the Professional repair....the picture isn't too clear but the repair was made from about 9:00 up to about 1:00 on my rim....
Hope this helps......<font color=blue>2old4this</font color=blue>
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Old Mar 28, 2004 | 10:56 AM
03G35Black's Avatar
on friday my rear tire went flat. i thought i had to plug the tire. when i went to have it plugged the guy told me the rim is bent and its not the tire. i was like, what the f. damn potholes. anyway, he told me of a body shop in elizabeth, nj that fixes rims. i went there yesterday but it was closed. im going back on monday. the spare looks disgusting. i was told its about 50-100 bucks a rim. its called, auto collision experts. 908-352-5991. 311 magnolia ave. if you are interested pm me and ill let you know how it works out.
Old Mar 29, 2004 | 10:14 AM
malx's Avatar
Yeah man I have big gauges on my rims. I have never driven a car daily with over 17" wheels so I wasn't used to it. I will repaint my wheels soon.
Thanks - Joey Avino
Old Mar 29, 2004 | 10:25 AM
gte192t's Avatar
Joey,
I've never driven even 17in rims. My G is arriving at the end of April and I was wondering what there is to get used to?
Thanks,
-Chris
Old Mar 30, 2004 | 07:14 PM
MrCynical's Avatar
Psssh I did that with about 300 some miles on it haha. Glad to get that one out of the way.
2004 Twilight Blue Coupe
6 spd
Premium Package
Aero Package
Old Mar 31, 2004 | 02:06 AM
ColdFusion's Avatar
xman -- your lucky they actually were able to match the paint on your rim. Every place i went to said that they couldn't match it and they said it would look totally different. There was one place that could do it but they were charging $300 to fix it and so i didn't get it fixed.
Old Mar 31, 2004 | 04:48 PM
GR8TG35's Avatar
I was very skeptic at first when my dealer told me they could do the repair....
I had checked with several on-line places and all but one said they could not match the color exactly, and I was better off getting both the wheels on that side painted so it wouldn't be as noticeable...
I was not about to have a perfectly good wheel repaired, so I gave the dealer a shot...
It was done by Alloy Wheel Specialists, they are located in Neptune, N.J.
The repair was limited only to the lip of my rim...if it would have been on the spokes as well,I probably wouldn't have risked it.....
Old Mar 31, 2004 | 05:10 PM
g35hwc's Avatar
If your rim is really bad or u want a professional job done.
Go to infiniti-parts.com they will sell u a reconditioned rim
for $189 plus shipping and your old rim.
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
