Best way to clean headliner on 07+
Old Apr 2, 2008 | 08:30 PM
Nomad1600's Avatar
Question Best way to clean headliner on 07+
Forgive me if this needs to go into a generic part of the site, since I didn't know if the 08 liner is different than previous years and models. I just had my G35 in the dealer's shop for a service and apparently the mechanic must have touched the fabric headliner and left a spot (either oil or grease).
Its a small spot but natch my eye goes right to it. I don't want to make it worse or bigger by using the wrong cleaner or technique so I thought I would ask for suggestions on both from the collective wisdom here. So... what would be the best way to remove the spot? Thanks in advance!!!
Old Apr 2, 2008 | 11:33 PM
mzannad's Avatar
I was told once that there is cardboard in headliners and getting them excessively wet can be a very bad idea. Thats all I know
Old Apr 3, 2008 | 01:50 AM
kool-aid's Avatar
I use baby wipes on mine, don't know if I should be but it works pretty well
Old Apr 3, 2008 | 06:59 AM
Garnet Canuck's Avatar
Traveling Administrator
Use 303 Spot Remover and dab lightly with an MF cloth.
Old Apr 3, 2008 | 07:12 AM
johnnyzee's Avatar
Folex carpet and stain remover
Old Apr 3, 2008 | 07:15 AM
RBull's Avatar
Rated M
Most any cleaner that will lift grease will do the job. It's preferable to use a white cloth such as a cotton terry towel so there won't be any transfer of colour. Dab the cleaner on, let a sit for a bit and rub with light-moderate force.
Old Apr 3, 2008 | 02:14 PM
Scrooge's Avatar
Woolite 1:10 ratio with a 2 damp terry cloth and a dry terry cloth. First spray one damp terry cloth lightly with the woolite mixture and then gentle start rubbing the area with the damp terry cloth and then use the other damp cloth to pick up the soap/dirt residue. Last blot it dry with the dry terry cloth.
Old Apr 3, 2008 | 02:28 PM
gte959s's Avatar
This is the best method:
-Wrap a gentel bristled 2.5"X6" brush with a terry cloth.
-lightly mist your rag with a cloth cleaner and gently brush the surface. with the towel side
-this will help promote evenly distributed pressure on the surface
-then brush with a dry side of the towel to remove residue
Old Apr 3, 2008 | 02:39 PM
Nomad1600's Avatar
Thanks everyone!!
Old Apr 3, 2008 | 03:06 PM
TOGWT's Avatar
Headliners:
Require special care and attention, as cloth type headliners are assembled with foam backing and usually glued to a fibre roof panel. If the headliner becomes wet, it can cause the head liner to delaminate and fall down. An interior cleaner (303 TM Fabric & Vinyl Cleaner) should be used. Spray onto a terry towel and wipe very gently
Do not spray products directly onto head lining. Wipe lightly making sure not to leave headliner wet. Inspect and re-clean as necessary. It is better to clean twice, rather than to allow the head liner to get too wet. An alcohol based aerosol glass cleaner may also work for this operation because of its quick evaporation. Vinyl headliners should be cleaned the same way.
Methodology
•Lightly brush the headliner with a natural-latex sponge or a horsehair brush, they have very soft bristles that are gentle and is specially made for headliners or leather surfaces, this will loosen dust / dirt and make vacuuming easier (for very light dust or lint use a rolling lint brush)
•Do not use a stiff brush as you may snag or tear the headliner material
•Lightly vacuum the headliner to remove loose dust
•Spray 303 CM Cleaner & Spot Remover on to a 100% cotton terry towel
•Cleaning the headliner a quarter section at a time, use very light and even pressure on the towel to work the cleaner into the fabric. Do not saturate the material or use much pressure on the towel
•Use a fresh, clean damp, 100% cotton terry towel to remove the soil / dirt
•Frequently rinse the towel in clean warm water to ensure all dirt I soil is removed
•If the vehicle is fitted with a sunroof, open it a couple of inches, as dust build up at the front edge.
•Clean this area before closing the sunroof and proceeding to the rear of the sunroof.
Duragloss 451 Fabric & Carpet Cleaner Aerosol Foam (FC) - a blend of surfactants, which gently foam away soil, oil and grease from fabric and carpet surfaces.
Spot cleaning - can be done without leaving rings on fabrics, carpet and velour - http://www.seriousperformance.co.uk/...oView_248.html.
Old Apr 3, 2008 | 03:09 PM
gte959s's Avatar
Originally Posted by TOGWT
Headliners:
Methodology
Spot cleaning - can be done without leaving rings on fabrics, carpet and velour - http://www.seriousperformance.co.uk/...View_248.html.
Was this copied and pasted or do you always right like this? HAHAHA
Old Sep 4, 2008 | 06:14 PM
Rhino_111's Avatar
I assume this process would be the same for any year G. Thanks for all the info. I hope it works! I got tire scuff marks all over my headliner from the tire shop putting my tires in my back seat and its driving me nuts.
Old Sep 5, 2008 | 06:53 AM
TOGWT's Avatar
It's copied and pasted from “Automotive Detailing Inside & Out, A Knowledge Base for the Perfectionist"– by Jon Miller
Old Sep 17, 2008 | 09:53 PM
in2win's Avatar
a damp microfiber with very light wiping action, to not imbed the dirt. Worked wonders on my 03 headliner. Youwould be surprised how much "smog" had mad a track on either side of the driver and passenger side from having the window down...now I know how my lungs feel.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
quikrotary
2nd Gen (V36) Sedan
11
Nov 19, 2015 05:14 PM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
dcsbh1
Oct 1, 2015 03:15 PM
vamarris
Sep 26, 2015 12:56 PM
