Is it safe to use buffer on clearbra?
Old Apr 20, 2008 | 06:43 PM
ClearBra_Guy's Avatar
Its not bad for it and will not hurt the film. You just don't want to make a habit of reaching for alcohol everytime something gets on the film. You should also use light pressure only. If you dig hard into the film you can distort it as it gets softer.
The best way to care for the bra is to use a good past wax on it regularly with quick detailer in between. That way if something gets on the film it will wipe clean with a quick detailer with ease. You should also stay away from any yellow wax. These waxes will stain the film over time. They are good for the paint but not the urethane bra.
Old Apr 20, 2008 | 11:21 PM
ABQ_G35's Avatar
The sap that is really bad here, occurs in spring, from cottonwood trees, they sprout these sticky little "shells" that the leaves pop out, when the wind blows, even if your not under a tree, you get those, and they stick to everything, and leave a chunk of sap. LOL, over the years, I've tried everything to keep them from sticking, including waxing, and they still stick! And the only thing that will remove them is the isopropol, 91%.
Old Apr 21, 2008 | 08:57 AM
thommyboy0885's Avatar
Just make sure you dont rub on it to hard if you use alchohol. I have had people bring their cars back to me after they tried it and they put to much pressure on the cloth. It will scratch the film up pretty bad if the cloth is abrasive or dries out to quickly. Then their is nothing left to do but replace the piece.
Old Apr 24, 2008 | 03:25 PM
ckg35's Avatar
Originally Posted by ClearBra_Guy
If you have Venture Shield then using a heat gun worked around the film in a circular motion to get the film warm but not hot will shine it up and get rid of scratches.
On the 3M film you use isopropyl alcohol on a soft rag. The alcohol will get rid of the scratches unless they are large and deep. If thats the case they are there for good. Once done just use wax or a good polish to bring back the shine.
Thanks for the tips! I'm going to try a light application of alcohol.
seagrasser
May 3, 2022 09:43 AM
jeffbdye
Jun 1, 2018 03:51 PM
yosip1115
16
Sep 28, 2015 04:14 PM
Terry_G35
Sep 10, 2015 08:17 PM
