Crazy glue removal
Old Apr 25, 2008 | 02:20 PM
Smokey6's Avatar
Crazy glue removal
Accidentally got a small amount of crazy glue on my drivers door at the bottom. Anyone know how to get this off?
Old Apr 25, 2008 | 02:22 PM
speedracerg35's Avatar
inside or outside?
Old Apr 25, 2008 | 02:24 PM
Deezflip's Avatar
if it's not on the paint, some small amount of nail polish remover, acetone, or rubbing alcohol on a piece of rag
Old Apr 25, 2008 | 02:32 PM
Smokey6's Avatar
on the exterior paint unfortunately...
Old Apr 25, 2008 | 02:35 PM
Deezflip's Avatar
hmm tough one, using any of those above can smudge your clearcoat.
Maybe Gunk's Bug and Tar remover? I would use a small amount of that too just to be safe.
Old Apr 25, 2008 | 06:01 PM
GR8TG35's Avatar
Try a little WD-40 lubricant. Just spray a blob on, and let it sit. If its able to penetrate under the glue, it should peel right off. The super glue still may have done damage to the paint though.
Good luck
Old Apr 25, 2008 | 07:10 PM
RBull's Avatar
Rated M
^+1 or try goo gone
Old Apr 25, 2008 | 08:03 PM
kenchan's Avatar
if all fails i would take a razor and shave off as much as you can,
mask the surrounding paint, sand the superglue blob down close to
even with the paint, and then use polish to finish off.
Old Apr 25, 2008 | 09:57 PM
G35Ian's Avatar
get a can of compressed air turn it upside down and blast away at the glue spot and freeze it, if it is small enough you should be able to take it off with your finger nail.
I've done this before to take bubble gum off my car.
Old Apr 25, 2008 | 10:01 PM
do not put a razor blade onto your paint unless you know what you are doing. unfortunately, the best way is to do it is 1800 grit wet/dry colorsand and buff. this is also a "do not attempt unless you know what you are doing".
Old Apr 26, 2008 | 06:28 PM
Smokey6's Avatar
Thanks guys - I'll give a few of these things a try and well see what comes of it.
Old Apr 28, 2008 | 12:28 PM
breftayka's Avatar
Goo Gone FTMFW!
Old Apr 28, 2008 | 02:39 PM
aRT13's Avatar
We had some really sticky tar on one of our cars on the exterior paint.
Used goo gone and it took it right off.
Always use small amounts. Apply to rag first, not directly on paint.
Gently wipe, etc. Personally, afterwards, I'd wash it with soap, clay the spot, and apply some wax.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
