Would using a sponge with a rough surface scratch...
Old May 30, 2008 | 11:17 PM
NewGuyG35's Avatar
..the bumper.
My only complaints with washing the car is removing the bugs. I think the only way I can remove them is by using some type of rough surface. I'm obviously not gonna use something made out of aluminum. Just wondering if it will damage the bumpers paint.
Old May 30, 2008 | 11:38 PM
blueboxer's Avatar
Even the softest microfiber can scratch your paint when you apply too much pressure or use it to drag debri along your paint with it. There is a bug remover product thread open with some product recommendations. It would be safer to use a dedicated bug remover to soak in and make it easier to remove them with less scrubbing.
Old May 30, 2008 | 11:46 PM
speedracerg35's Avatar
get a can of bug and tar remover at pep boys. do not use any rough surfaces on your car.
Old May 30, 2008 | 11:48 PM
NewGuyG35's Avatar
I already use a bug and tar removal spray but doesn't work all that great. Maybe i'll just try another one.
Old May 30, 2008 | 11:57 PM
Garnet Canuck's Avatar
Traveling Administrator
I use Poorboys Bug Squash and it works great for removing all the bug crap from your front bumper and grille. Btw, I can't believe you even mentioned aluminum in the same post as detailing your car.
Old May 30, 2008 | 11:59 PM
gary c's Avatar
Scratches & Swirls=Nightmares!
So you don't scratch your clear coat, soak those bugs a lot using the typical
car wash soap and carefully give them a blast with a pressure hose. Then
load up your sponge with water and carefully (again) wipe off what's left.
The last thing you want to do is get aggressive scrubbing your paint...
Gary
Old May 31, 2008 | 12:45 AM
NewGuyG35's Avatar
Yeah I know. But people always come to extreme conclusions so I figured I throw that out the window.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
KruZZe
Feb 27, 2023 05:04 PM
dcsbh1
Oct 1, 2015 03:15 PM
vamarris
Sep 26, 2015 12:56 PM
doakley92
Sep 25, 2015 12:58 PM
