Save ~30% or more EVERYDAY at DetailedImage.com!
Old Sep 22, 2009 | 08:37 AM
  #406
Detailed Image's Avatar
Today's Daily special (September 22, 2009) is Chemical Guys MetalWax - Ultra Fine Metal Polish & Protection.
Regular Price for 16 oz is $12.99. Today's price is $9.74!
  • Restore your metal surfaces to a brilliant shine and protect the finish all in one step
  • Ideal for polishing wheels, metal and chrome trim, interior metal trim and more
  • We recommend using a foam applicator pad for application
Old Sep 23, 2009 | 09:30 AM
  #407
Today's Daily special (September 23, 2009) is Clay Magic Medium Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $20.80!
  • Remove embedded surface contamination that does not come off during the washing process
  • Medium grade bars will remove contamination quickly, however it may result in micro-marring
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Follow up the medium grade clay bar with a finishing polish to remove any micro-marring
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Old Sep 25, 2009 | 10:57 AM
  #408
Today's Daily special (September 25, 2009) is Menzerna Super Intensive Polish PO83.
Regular Price for 32 oz is $44.99. Today's price is $33.74!
  • Our best medium cutting polish that is known to remove moderate imperfections in the clear coat
  • Most noted for its ability to cut well, good work time, easy removal process and great finish
  • On lighter colored vehicles, it is not always necessary to follow up with a finer polish
  • On darker colored vehicles, we recommend following up with a finer polish, such as PO106FF
  • Most commonly applied with an orange light cutting pad when using a buffer
Old Sep 26, 2009 | 11:07 AM
  #409
Today's Daily special (September 26, 2009) is Chemical Guys Luber.
Regular Price for 16 oz is $9.99. Today's price is $7.49!
Regular Price for 128 oz is $24.99. Today's price is $18.74!
  • An outstanding clay bar lubricant formulated to work specifically with your clay bar
  • Can also be used as a quick detailer to remove a light dusting along
  • Works great with the Chemical Guys Fine Grade Clay Bar
Old Sep 28, 2009 | 07:39 PM
  #410
Today's Daily special (September 28, 2009) is Optimum (OPT) No Rinse (ONR).
Regular Price for 32 oz is $15.99. Today's price is $12.15!
Regular Price for 128 oz is $39.99. Today's price is $31.81!
Regular Price for 8 oz is $7.99. Today's price is $5.99!
  • One of the must haves for any auto detailing enthusiast or professional, simply revolutionary
  • ONR is perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
  • All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
  • Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
Old Sep 29, 2009 | 01:30 PM
  #411
Today's Daily special (September 29, 2009) is Gilmour Flexogen 8 ply Hose.
Regular Price for 50 feet is $34.99. Today's price is $26.34!
  • One of the most durable hoses available with the thick 8 ply construction
  • Minimize kinks that slow down water flow
  • Full LIFETIME Replacement from Gilmour ensures complete satisfaction
Old Oct 3, 2009 | 12:24 PM
  #412
Today's Daily special (October 3, 2009) is Dodo Juice Hard Candy Hard Wax.
Regular Price for 250 ml is $64.99. Today's price is $50.49!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
  • A Dodo Juice hard carnauba wax designed to work on any colored vehicle, light or dark
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
  • Apply with a foam applicator pad and remove with a plush microfiber towel
Old Oct 4, 2009 | 11:54 AM
  #413
Today's Daily special (October 4, 2009) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a heavy cut compound to remove deep imperfections and wet sanding marks
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old Oct 5, 2009 | 08:06 AM
  #414
Today's Daily special (October 5, 2009) is Chemical Guys Simply Leather.
Regular Price for 16 oz is $8.99. Today's price is $6.74!
  • Fresh leather smell
  • Spray on fabrics or wipe on interior
  • Eliminates bad smells by breaking down odor causing bacteria
Old Oct 5, 2009 | 10:51 AM
  #415
ttrank's Avatar
Grocery getter
I should have gotten some of that with my last order too. Oh well, the next order won't be far down the line.
Old Oct 6, 2009 | 06:10 PM
  #416
NgoFrickinWay's Avatar
Sent an order in for some stuff Sunday and should be getting it Friday. Hopefully the weather stables out this weekend so i can give them a shot. w00t!
Old Oct 7, 2009 | 09:56 AM
  #417
G:Luv's Avatar
George,
I see that DI now carries Meguiars products. I'm interested in the glass clearner, but I don't see that it's available. Any chance you'll carry that as well?
Old Oct 7, 2009 | 01:23 PM
  #418
ttrank's Avatar
Grocery getter
My new order should be here soon too! I'm excited to try the Dodo supernatural!
Old Oct 7, 2009 | 10:27 PM
  #419
Thanks for the support guys, looking forward to hearing about your details.
Originally Posted by G:Luv
George,
Meg's is going to be an expanding line for us. We started with what we felt were some of the essentials and we plan on adding more as we continue to reorder with them. I'll certainly take it into consideration, greatly appreciated!
Today's Daily special (October 7, 2009) is Chemical Guys Fade 2 Black.
Regular Price for 13 oz is $12.99. Today's price is $9.74!
  • One of the most unique trim restorers that turns faded trim back to a deep factory black finish
  • Perfect option for wheel wells, engine bay dressing, tire dressing and exterior trim pieces
Sorry for not replying sooner, I've been working on getting Meg's up on our site the past 2 days.
Cheers,
George
Old Oct 8, 2009 | 02:35 PM
  #420
Today's Daily special (October 8, 2009) is Klasse High Gloss Sealant Glaze (HGSG).
Regular Price for 500 ml is $20.99. Today's price is $15.96!
Regular Price for 1000 ml is $27.99. Today's price is $21.28!
  • One of our longest lasting sealants that looks best after multiple coats
  • Can be finicky to remove, so we recommend wiping on and wiping off, working in small sections
  • Apply with a foam applicator pad and remove with a quality microfiber towel
  • Properly prep the paint with Klasse All In One chemical polish
