help!!! stain covering gauge cluster
Old Jul 10, 2008 | 01:25 AM
Rhart's Avatar
so i got my car today, and when i drove around at night i saw a stain i cant remove on the plastic cover. i tried to clean it but now i think the stain is inside the plastic cover. im wondering how it got in there. its hard to see the gauges with it and i want to fix this asap. is this covered under factory warranty? brand new car and already got problems for me =(. any help would be appreciated. thanks
[IMG][/IMG]
[IMG][/IMG]
Old Jul 10, 2008 | 07:39 PM
bythabay's Avatar
wow.. that sucks... you could try removing the cluster and polishing/cleaning the lens.
Old Jul 10, 2008 | 07:52 PM
Deftronix's Avatar
looks like someone cleaned it with something that ate away the surface. GL
Old Jul 10, 2008 | 07:55 PM
Rhart's Avatar
anyone know where i can buy a replacement lense?
Old Jul 10, 2008 | 07:58 PM
bythabay's Avatar
i think you'd have to buy another cluster and swap lenses with it.
Old Jul 10, 2008 | 08:01 PM
10nara's Avatar
contact this guy, he was desparate to sell.
https://g35driver.com/forums/archived-sales/223454-fs-05-cluster.html
Old Jul 10, 2008 | 08:09 PM
twin001's Avatar
certain glass cleaners will do that to the plastic cover. Apply some wax (the same kind you wax the car with) to it and rub it in, don't wipe it off. It may take a few applications over the course of a few days but it will look much much better and you will actually be able to see your gauges again. Good luck!
Old Jul 10, 2008 | 08:29 PM
Dxplicitone's Avatar
Bro i just picked up my car and it has the same exact problem (not as bad) but its got the same spots and haze that your cluster has from what seems to be a cleaner. I tried to clean that ish with everything... from heavily diluted Poorboy's APC, to using some Ice liquid clay bar (its what i use on my headlights and works well), and even went as far as to grab a little 3M Micropolishing compound to knock it out and i had little luck removing it to a level of happiness for myself. I can see my gauges but when looked at with a close eye you will notice the splotched and imperfection from the previous cleaner that was used. Im on the hunt for a new piece myself and id advise you do the same thing as its not an easy piece to repair and might be more cost effective to save the time and get a new piece. Ill keep you in formed if i have any luck with finding one in hopes that you will do the same for me if you do also.
Good luck.
Old Jul 10, 2008 | 08:33 PM
officerdbag's Avatar
I have a line just going all the way across my cluster just like that bluriness. It pisses me off. It happened when the dealer was prepping the car for me to pick up when I bought it.
Mine looks like that, it looks like dried armor all to me.
Old Jul 10, 2008 | 10:25 PM
Infiniti5150's Avatar
This usually happens when you spray protectants such as armor all or formula 2001 and it sits on there as little as 30 mins. Try to use this stuff I use made my Meguairs called plastx clear plastic cleaner and wax.
Old Jul 10, 2008 | 11:46 PM
archie's Avatar
take your pick
http://www.autodetailingsolutions.co...tic-polish.htm
Old Jul 11, 2008 | 12:30 AM
Rhart's Avatar
cool thanks!, can i find these at* stores like kragen?
Old Jul 11, 2008 | 09:28 AM
archie's Avatar
you can find plastx in stores. the cheapest place to buy it for me in so cal is walmart. as for the professional products its a hit or miss depending on your local kragen or autozone. you can hope on meguiars.com and locate a store near you that sells the professional line though.
Old Jul 12, 2008 | 12:32 AM
dreamcatchr's Avatar
to the OP, i had a similar problem on my boxter and i used meguiars #17 (plastic cleaner) and #10 (plastic polish) and it fixed the problem (as close to perfect as i could have hoped... good luck...
Old Jul 12, 2008 | 01:51 AM
Scrooge's Avatar
Yeah it happen when I use a dilute apc on my interior. I had to buff the heck out of the plastic with a terry cloth and plastic polish (Meguiars plastix). It got it out and good. Next I'll be more cautious when cleaning next to that area.
