Washing car under freezing temperature
Old 12-04-2008, 08:07 PM
VstyLe09's Avatar
forgot to mention the car is still iced still waitin for it to melt so i cna towel ]dry it =]
Old 12-04-2008, 08:17 PM
Mike Zajac's Avatar
I embrace the elements.
Old 12-04-2008, 09:31 PM
Don @ Migliore's Avatar
Former G35 Sponsor
ONR is definitely the new solution for cold temperatures.
But yeah, I doubt you'll get frostbite. I've washed many cars with temperatures in the teens and I wasn't affected. I've even had several ice skating rinks form around the cars, as well as the water freezing almost instantly as it hits the paint.
Old 12-04-2008, 11:01 PM
JOKER's Avatar
CLUB MODERATOR
http://www.autogeek.net/optimum-no-rinse.html
Search it, a lot of detailers use it on a regular basis, its not just for winter washing.
that's ghay
Old 12-05-2008, 02:31 PM
Jeff92se's Avatar
Red Card Crew
Does this product replace some of the spray sealants (Optimum and Duragloss) on the market?
How wet does the microfiber have to be when you use ONR? Like water dripping down wet like you would normally wash with a mitt?
Old 12-05-2008, 03:15 PM
redlude97's Avatar
It does not have any protection abilities I am aware of. The towel/mitt should be saturated, but not dripping to minimize the amount that ends up on the floor.
Old 12-05-2008, 03:37 PM
dreamcatchr's Avatar
ONR ftw... you dont have to overcomplicate it, it's a very simple process that works perfectly...
Old 12-05-2008, 03:38 PM
Jeff92se's Avatar
Red Card Crew
I wonder if I could spray my duragloss sealant after washing but before wiping?
Old 12-05-2008, 03:42 PM
redlude97's Avatar
There are people who do this. Search on autopia.org. I don't personally, but they seem to have good results
Old 12-05-2008, 03:44 PM
Jeff92se's Avatar
Red Card Crew
Any particular reason not to?
Old 12-05-2008, 03:50 PM
redlude97's Avatar
There is still dirt on the car before you dry. If you apply a sealant while removing this dirt, you could potentially seal in some of the dirt onto the surface.
Old 12-15-2008, 04:04 PM
Jeff92se's Avatar
Red Card Crew
Does one go though alot more microfiber towels when wiping off the water/ONR-QEW? Because each time you wipe, you'd have a dirty towel. So does one tend to use maybe 3-4 towels each time?
Old 12-15-2008, 05:02 PM
Ghaleon0721's Avatar
You have two things working for you here.
1) ONR 'encapsulates' the dirt. On a molecular level, dirt gets 'trapped' in the ONR solution. that's why it doesn't scratch your paint when you wipe. So even though the water is dirty, the dirt is securely encapsulated in the solution.
2) The magic of Microfiber. Microfiber is designed to absorb dirt and pull up into the pile and trap it in the fibers.
I use two meguiars water magnets to dry my car. The first pass should only pick up 80-90% of the dirt. Then I use a Quick detailer as some added lubrication on the second pass. this provides more lubrication, and prevents streaking (something ONR is notorious for).
Old 12-15-2008, 05:47 PM
Wannabe6MT's Avatar
-MN G Crew-
Im currently just running to this car wash because, well, it is easy and doesnt take time.
But, does this stuff work when your car looks like this?
You'd think it would just rub the dirt around and scratch the paint, esp when their is ice/snow and standing salt on the paint.
And also, how long does it generally take to wash the car using this method? Is this a once a week thing? Because im extremely **** about dirt on the car and it seems to get dirty right after i wash it so i usually do it again 2 days later...
Thanks for the input, im really looking into this stuff.
  #30
Old 12-15-2008, 06:47 PM
redlude97's Avatar
I fold my MF's into quarters. Each washed section gets 2 passes. I use each quarter of the MF twice. Each clean quarter of the MF is used for the second pass on a section of the car, and the second time the quarter of the towel is used is to pick up the majority of the water from a washed section for its first pass. Hopefully that makes sense. With a large waffleweave MF and two small ones, I can dry the car, and then 1-2 normal MF's for touch up and any spots I miss.
Quick Reply: Washing car under freezing temperature
