Washing car under freezing temperature
32 is not bad
If you car is garage kept then the body panels should be a bit warmer then that.
If you use hot water (in a bucket) then you should not have any issues.
I don't when I wash it in such temperatures.
Now if you keep your car outside in the cold them you might have slight problems. In that case just get couple of buckets of hot water and simply dump it on the car to warm it up a bit before the wash.
