my g a test subject ?
Old Dec 31, 2008 | 10:27 AM
sswamp's Avatar
have had my ob coupe for just about a week now . looks pretty good but in the right light and angle , i can see all the scratches and swirls . want to fix that but damn scared to learn how to use a pc on this car . question is ... how many of you did just that and with what results ??
Old Dec 31, 2008 | 11:50 AM
DetailDan's Avatar
The PC is extremely easy to use and its hard to permanently mess the paint up. Buy one and give it a shot.
Old Dec 31, 2008 | 12:51 PM
TheTick's Avatar
pc is pretty much fool proof. I've done several cars and it definitely works. However, it isn't the most powerful machine so it takes a long time to do an entire car. It also vibrates a lot so your hands will get pretty chapped.
The Flex is another safe polisher more powerful andmuch smoother, but more expensive. This would probably take a couple hours off of doing your entire car.
A rotary would do your entire car in no time, but you can do serious damage to your paint if you are not careful. Don't let this scare you though. Just do some research and they easy to use with some practice.
After doing several cars with a pc, i've decided that I just can't do it anymore. It just takes too long and I'm always sore the next day. I'm going rotary. If you only plan on doing your car a couple times a year, the pc will be fine if you have the patience.
Old Dec 31, 2008 | 02:21 PM
sswamp's Avatar
thank you for the thoughts . i think my biggest worry is the polishing part . ill find something to practice on first . untill i think im ready ... does anyone know of a quality detailer here in east , central florida ( daytona ) ?
Old Dec 31, 2008 | 04:15 PM
Darkstar752's Avatar
PC 7424 is extremely easy to use. I would do your G as a test subject. If you are really worried, go pick up a scrap hood or other panel from a local body shop to practice on.
Old Dec 31, 2008 | 04:37 PM
TheTick's Avatar
If you get the PC, there's nothing to worry about. 5.5" orange and white pads with Menzerna polishes will give you great results!
Old Dec 31, 2008 | 05:17 PM
superchargedg's Avatar
I started out using the pc and didnt get any of the results i thought i would.So being the hard headed tech that i am i went at it again but still very little.I then decided to watch the videos and practice and found i was going to fast and never let the polish break down.
Just do yourself a favor and watch the vids and in no time you should be able to get good results..........just remember slow is good with the pc.
Old Dec 31, 2008 | 07:54 PM
TheTick's Avatar
good advice superchargedg. This is why it takes forever to do a whole car with a PC. With time and effort, it really does work. If you have mild swirls, I highly recommend menzera's Power Finish. It is a good one step. Its too much work to do a 2 step with a PC.
Old Jan 1, 2009 | 06:54 PM
sswamp's Avatar
thanx again for the replies . looked a little closer and believe a panel or two may have been repainted . not a bad job but oranged peeled a bit heavier in places . will polishing smooth that out also ?
Old Jan 1, 2009 | 08:10 PM
deniance's Avatar
whoa hold up!!!!!!!! dont just go running into your g armed with polish and a pc **** no, paint on my g is thin as hell,, the readings on my roof are 80-90microns which is low but on the hood they are as low as 50, thats why these g's get chipped so easy, if you polish away you run the risk of getting too thin on the clearcoat and it could start to fail and end up flaking off,trust me dont do it, ask a pros advice first there are prob some members on here who r detailers ask them first!!!!!!!
Old Jan 2, 2009 | 03:02 AM
TheTick's Avatar
You normally want to wetsand to smooth out the orange peel. Then use a compound to polish then finish polish. won't be easy with a PC but doable.
KruZZe
Feb 27, 2023 05:04 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
Visionnn
Oct 3, 2015 05:16 AM
