Is there a trim blackener for bottom trim?
Old Jul 1, 2004 | 10:52 AM
exagorazo's Avatar
I am looking for a product to blacken the bottom trim piece that goes around the bottom sides and front of the car. Also, there is black trim around the mirror mounts that appears to be of a different material that I would like to blacken.
Can anyone recommend a product or a solution?
Old Jul 1, 2004 | 11:04 AM
andyranck's Avatar
Re: Is there a trim blackener for bottom trim?
Armor All.
Drew
2003 G35 Sedan 6MT / Black / Graphite / Prem / Aero
Old Jul 1, 2004 | 01:05 PM
SixFive's Avatar
NO ARMOR ALL. This is bad for the finish. i will look for you tonight but a small white bottle of stuff i got at a high dollar car wash and made just for black plastic trim. The stuff wont leave white dry streaks like armor all and is very clean and lasts until you get more dirt on it. Peanut oil works very well if you dont mind the smell and the oily residue on your hands and rags.
2003.5 DP 5AT Sedan (E-thing but Nav)
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Jul 1, 2004 | 03:18 PM
Blitzjb's Avatar
www.griotsgarage.com
<font color=green>04 G35C DG AT
Prem Aero Perf RSG CC
2004 Pathfinder for the family
</font color=green>
Old Jul 1, 2004 | 03:54 PM
Diesel1's Avatar
Moderator
I would avoid armor all too. It will streak the sides of car after the first rain. There is a product called Forever Black that is the actual dye that manufactures use (supposedly). I used it on my Explorer to dye the faded black molding (every explorer had the same problem). They were almost white. I used 2-3 coats of this stuff and it lasts for years. If you want to do the area near your mirrors, I would rather take it to a body shop and have them paint it. If you don't want to go that route, I would take the mirror off and test a patch of the plastic that will be hidden by the mirror first. See how it dries. If it's all good, mask off the area around the mirror (just in case you drip) and give it a few coats. Multiple coats will eliminate streaking. Also, with the mirror off, you will be sure to get the entire area. If you leave the mirrow on, their will be spots you just won't be able to reach.
2003 6MT Black Coupe, Premium Pkg. w/ Aero
20% tint all around, Aluminum Pedals
Old Jul 1, 2004 | 10:31 PM
ABQ_G35's Avatar
Mother's makes a product called "Back to Black" expressly for black and flat black trim, I had used it on a previous vehicle, but haven't needed it on my G yet (9 months) it's looking good just keeping it clean so far!
Brilliant Silver/Graphite/Chrome Wheels '04 Sedan/5AT
Old Jul 2, 2004 | 08:53 AM
SixFive's Avatar
Thats what i have - good stuff and easy to apply - i dont keep the "wet look" but use it once every 2 months or so as the plastic is easy to wipe clean with a damp rag.
14.2 @ 97.18
Z-Tube
UR Crank Pulley
Old Jul 3, 2004 | 07:48 PM
exagorazo's Avatar
Tracked down Mother's "Back to Black" and used it with excellent results. Thanks very much for the tip. I would also classify it as "highly recommended.".
For the first application, I was short on time so I just applied it right over the dust to see what would happen. I was expecting the product to be a black, "better not spill it on your clothes," shoe polish type paste. To the contrary, it was a milky, translucent, thick liquid which I applied and later rubbed out with a heavy duty paper towel.
The results were excellent, even with my poor application technique. It achieved about 90% of the showroom black appearance, and, with proper cleaning ahead of time and a couple coats, the black trim will look just like new.
Tmatheso
Dec 13, 2015 03:24 PM
mbe32
Nov 13, 2015 11:09 PM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
master111
Sep 25, 2015 08:32 PM
toadfire
Sep 21, 2015 07:15 AM
