Apply Zaino in the Sun?
Old Jul 10, 2004 | 01:19 PM
milanoa's Avatar
Is it ok to apply Zaino on a hot day in the sun? I read the instructions and it did not seem to say that you can't though I don't want to if it has any negative effects. Anyone have any experience in this area?
Old Jul 10, 2004 | 01:27 PM
Xman's Avatar
Re: Apply Zaino in the Sun?
Which product?
I've applied Z2 and Z5 in the sun with no problem although I usually try to wait toward the late afternoon. I've also applied Z6 gloss enhancer in between treatments after wash/dry in sunlight too just don't let it dry before you buff.
2K4 G35x/Brilliant Silver/Graphite/Premium/Wood
Stillen Hi-Flow/ Z tube/ Crawford V5/ Ground Kit
Old Jul 10, 2004 | 02:36 PM
milanoa's Avatar
Thanks today I am doing Z-2 and Z-6.
Old Jul 10, 2004 | 03:46 PM
bkchang79's Avatar
The zaino dries much quicker under the sun which is easier to wipe it off.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
http://www.sounddomain.com/id/bkchang79
Old Jul 10, 2004 | 04:29 PM
GeoBau's Avatar
Cactus Hugging Admin
I parked my car in the shade, applied z2, and then parked it in the Vegas sun. Dried within minutes. I waited quite a while (hour or so) to buff it off, but for some reason, the final bit of residue seemed to not want to buff off at all. It just pushed around. I know it was dry, but do you think the surface temp of the car kept it in a semi-liquid state?
G
2003.5 Black w/ Willow G35
Premium / Sport / Aero / Winter / Navi / Tint
<font color=blue>Z-tube, Pop-charger, Borla True-Dual Exhaust, Eibach Pro Kit, GroundingGear</font color=blue>
Old Jul 10, 2004 | 06:32 PM
afr0puff's Avatar
Supa Dupa Moderator
Don't spray Z-6 onto the car! Spray the towel, then rub on the car for best results when using zaino in the hot sun.
http://www.anythingbox.net
Old Jul 11, 2004 | 02:41 PM
treachery's Avatar
Don't use Zaino when it's really hot out. I did one day when it was 95F out on a black sedan, and the Z1 evaporated as soon as it made contact. Should've been a hint to stop, but I went ahead anyway with the Z1/Z2/Z6. Now, I've got streak marks all over my car - you can see the motions I used to buff the car. When I get less lazy I'll go back and strip the wax, then redo the entire process.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
mattdg35
Sep 14, 2015 11:28 AM
Spartan268
Aug 20, 2015 09:14 PM
Detailed Image
Aug 7, 2015 02:10 PM
