Remove bad smell
Old 07-04-2009, 07:46 PM
Parker6's Avatar
Remove bad smell
So I recently found a dead mouse on the backseat floorboard of my car...I have no idea how it got there. Just wondering if anyone has any helpful tips to get rid of the bad smell that is left in the car. I used frebreeze and left it opened up to air out, but its still there a little.
Old 07-05-2009, 10:21 AM
Detailed Image's Avatar
What I typically do is scrub the carpet with a deoderizing cleaner, something like Chemical Guys Fabric Clean works great. Then after cleaning, I'll put a plate of baking soda near the affected area. Be sure to remove it before you drive as you don't want it going all over your car.
Hope this helps,
George
Old 07-05-2009, 12:31 PM
emulb's Avatar
an ozone machine will work wonders but they are expensive, there might be a place you can rent one
Old 07-05-2009, 01:44 PM
J2S2M's Avatar
Why not replace your floormat. I personally would not be using a floormat that had dead rat sitting on.. *barf*
Old 07-07-2009, 09:16 AM
RBull's Avatar
Rated M
Hope this helps,
George
+1
Also consider picking up a cleaner/deodorizer with enzymes that "eat" organic matter you're smelling from the rat remains. I use "odourstroyer" from Zep.
Old 07-07-2009, 10:15 AM
Lords47's Avatar
Years ago, I heard a theory that if you put coffee grinds onto a cookie sheet, and leave it in your car overnight, it absorbs the smell. My first car was a smokers car. I did the coffee grind thing, and it worked quite well actually. (I wouldn't brew it though hahaha)
I suppose this is along the same line as baking soda.
Old 07-07-2009, 11:04 AM
I'll have to try this technique next time around. When you're smelling cologne or perfume at some stores they have a jar of coffee beans to smell to help forget the smell of the last scent you tested. I bet it does a good job as you said. I'll skip on the brewing, haha.
Thanks for the tip.
George
leo38cheng
08-09-2015 12:14 PM
newg37
07-26-2015 09:32 AM
lemmy999
07-25-2015 12:13 PM
justgotg35
07-19-2015 12:33 PM
Quick Reply: Remove bad smell
