it worked! take that plastx
Old 10-13-2009, 08:04 PM
Envious Eric's Avatar
most headlights will clear up with 1500, then 3000, then a polish via rotary. The thing is you have to seal them up, or re-clear them so the yellowing/oxidizing will not take effect so fast!
Old 10-13-2009, 08:14 PM
Locksmith's Avatar
Nice work
Old 10-13-2009, 09:53 PM
bocatrip's Avatar
If you get the Meguiars on your headlights when the fogging is in the early stages, you will be able to avoid the yellowing/hazing that becomes a job to remove.
Old 10-24-2009, 09:10 PM
blackhat5's Avatar
I just bought and used the 3M Headlight Restoration kit on my headlights which were literally eaten up and cracked from a chemical. This made my headlights look brand freaken new I am VERY impressed. Only thing that sucks is that I can see fine scratches all over the light snd wet sanding and compound wont take it out.
Old 11-29-2009, 07:29 AM
COBB 30066's Avatar
3M on sale now at NAPA $14 after rebate
I just bought and used the kit. It is on sale at Napa for $16.98 with a mail in rebate for another $3.00.
My lights look much better but still a light haze. I have used 2 kits and still have fine scratches. I assume I need to do more 3000 sanding and polishing.
Any particular brand/type of clear coat recommended for a top coat when I get the headlights the way I want them?
Old 11-29-2009, 09:02 AM
Braintree's Avatar
I've been using toothpaste for >20 years on plastic headlights and then finishing the process with Collinate #845. Toothpaste has a polishing compound, which is just as effectove than the more expensive products being sold for this.
Just take about 1/2 teaspoon and hand or towel rub it on the headlight for about 2-3 minutes. Use a slight amount pressure (5-8lbs), rinse and repeat the process 2-3 times, then completely rinse the headlight and dry it. Once dry, apply 3-5 coats of a good wax or sealant that is long lasting (Collinate, Black Magic, NuFinish-- you're looking for durability and not depth). Apply a coat, buff out and wait a few minutes, reapply and buff, wait again, then apply and buff. This should last 4-6 months, even in the winter snow with salt on the roads.
It takes less than 20 minutes total and costs about 25 cents.
Old 11-29-2009, 12:17 PM
Texasscout's Avatar
Received 2,116 Likes on 1,768 Posts
That's what my bodyshop man said, no need to clear coat, just give it a good hard wax.
Old 07-25-2010, 06:56 PM
The Fapsmith's Avatar
Yea man I wouldn't mind trading my 04 headlights for the paintwork on the new projectors and grill. Just lemme know what deal you are thinkin
Old 08-13-2010, 10:55 AM
SLVR JDM's Avatar
Great results!
When I need a deep headlight cleaning, I wetsand (1000 -> 1500 -> 2000 -> 2500) then follow up with Plastx. Comes out like new!
Old 08-13-2010, 03:24 PM
AustinG35's Avatar
Originally Posted by ClearBra_Guy
To keep from getting the haze back you can get a head light clear bra kit and never have to touch them again. Once that coating is gone they will require up keep otherwise.
+1 yep, it was the best part of my clear bra investment, the material on the head lights is a little thicker than what is installed on your paint, but after 6+ years, my head lights still look brand new!
arora_g35
06-24-2020 01:58 PM
obender66
18 Inch
03-13-2016 12:20 PM
Big C
19 Inch
11
10-03-2015 05:11 AM
JMSABO
08-04-2015 11:58 AM
attarday
07-15-2015 04:03 PM
Quick Reply: it worked! take that plastx
