which one .. p21s or nanowax
Old Aug 18, 2004 | 12:02 AM
mashibee's Avatar
hi guys .. which one is better ... i am using CG... can i put p21s or nano after CG ? and what you use to put nano on ..
Old Aug 23, 2004 | 04:06 PM
NYCXLR8's Avatar
Re: which one .. p21s or nanowax
I am currently using Nano on my black coupe now. I had Zaino on the car prior and had to strip it prior to using the Nano. The dawn process does not affect Zaino since it is not really a wax (learned that from the thread I started on the subject).
I'm not sure what the end result would be if you applied the Nano on top of the CG.
2004 G35c 5AT/Prem Pkg/18" Tire Opt/Aero Kit/Clear Sides/Pedal Kit/Tint/Z-Tube/K&N Drop-in/Smoked Rear Overlays
Old Aug 23, 2004 | 05:23 PM
al503's Avatar
It all depend on whether nanowax has polishing (abrasive)properties. If it does, it may strip some of the CG or Zaino, or whatever. If it doesn't, you should be fine using it as a topper. To play it safe, just use the p21s or S100 if you can't find out.
Detailed Image
Sep 28, 2015 07:04 AM
GThIrtYFiZle
Picture Share
21
Mar 27, 2008 09:18 AM
CodingDane
Feb 28, 2007 12:57 PM
NYCXLR8
Sep 15, 2004 01:13 PM
NYCXLR8
Aug 11, 2004 08:59 AM
