HELP! scratches from debadging
Old Aug 20, 2004 | 03:50 AM
takuyaah's Avatar
i debadged my g35 letters on my coupe and i followed the method of using the blow-dryer..anyway..i cleaned up the glue by rubbing them off with my fingers. I guess i scratched it so now it seems like there's some scratches on that particular spot. What can i do about it? i washed it and everything so its not some residue and i believe i really scratched it =( please help?
Old Aug 20, 2004 | 07:11 AM
Blitzjb's Avatar
Re: HELP! scratches from debadging
Put the badges back on to cover the scratches.
NY G SQUAD<font color=red>&lt;---Official Website
Old Aug 20, 2004 | 11:37 AM
Premier's Avatar
You have to buff those scratches out w/ a buffer/
Certified Window Tint & Detailing Specialist
3M / VentureShield Paint Protection Film Dealer
Madico Window Film Dealer
syu@machiii.net
2003 AT Sedan / 2004 6MT Coupe
Old Aug 20, 2004 | 01:32 PM
al503's Avatar
If you don't have a buffer, try some scratchx by meguiars. You can use it by hand and rub it in one direction (up and down preferably). After you get the scratches out, a good quality wax will probably hide any scratches that are left.
Old Aug 20, 2004 | 01:52 PM
takuyaah's Avatar
thanks guys...i will most definitely try...anything fails...i am gonna put the badge back on.
how do you remove zaino? i already applied 2 coats.....if i wanna use scratchx then i need to remove it first right? but how?
Old Aug 20, 2004 | 04:40 PM
al503's Avatar
Scratchx will remove the zaino. Just zaino again after getting rid of the scratches.
Old Aug 20, 2004 | 10:16 PM
takuyaah's Avatar
not sure if i did it wrong (i don't think so since its pretty simple...apply on the scratch....let it dry...wipe it off) but seems like not much difference from b4 i using scratch x...i guess i just have to live with it for now...
Old Aug 21, 2004 | 01:00 AM
al503's Avatar
are you rubbing the scratchx into the paint with a towel? It'll take at least a few minutes of rubbing by hand to notice much of a difference.
Old Aug 21, 2004 | 04:21 AM
CKwik's Avatar
Depends on the depth of the scratches. If it's not to deep, a good polish or filler type of wax will probably do the trick. You should have used some adhesive remover to remove the glue residue. The 3M stuff is pretty gentle on paint. It will remove wax, but much better than scratching paint.
Old Aug 21, 2004 | 03:41 PM
takuyaah's Avatar
i applied the scratchx on the scratch with a applicator....i kinda rubbed it on for like..5 secs...and then left it on for..maybe 15 mins...and then wiped it...did i do it wrong?
Old Aug 24, 2004 | 07:32 AM
takuyaah's Avatar
bump...help please? =)
Old Aug 24, 2004 | 07:57 AM
GR8TG35's Avatar
takuyaah.....
Depending on how deep the scratch is, you may not be able to remove it completely.
Try rubbing the scratch with some applied pressure in cross cut or diagonal passes. this will help to round out the two edges of the scratch so it will not be as noticeable....then when you wax, it will fill the scratch area providing a better result.......
I can tell you from my own experience just wiping on the polish and lettling it stand will do nothing more than add a layer of protection to your paint.....in order to eliminate the scratch you need to cosmetically remove the surface damage to restore the finish.......
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Old Sep 1, 2004 | 12:59 AM
WRAH's Avatar
WRAH
I just did a number on my car! Prob. need a pro to get it out or repaint. I post some pics when I have some light!!!
Tmatheso
Dec 13, 2015 03:24 PM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
dcsbh1
Oct 1, 2015 03:15 PM
vQFamily
Sep 30, 2015 01:17 PM
