craftsman rotating orbital buffer
Ok, now that you're done laughing. I've had this for probably 10-12 years. Can I use this as a basis to start building off of, or do I need to spend money on the newer buffers that are out there? I've got 3 black cars and most of my effort, historically, has been spent around performance. I need to start making these shine a bit better. Thanks.
If you want the opinion of a professional detailer then you should https://g35driver.com/forums/care-de...-detailer.html and be prepared to give the specs of the Craftsman, like rpm's so he can tell you if it will work.
I have a similar RO buffer I've never tried polishing with it but it defiantly speeds up the waxing process. I don't think it can generate the speed and heat needed to completely polish out swirls and scratches but it defiantly won't hurt your paint any. I have used meg scratch x by hand and it helped to diminish the swirls so maybe with the RO it could get some better results but don't expect the same results as with a rotary or DA polisher.
I had one twice that old and tried using it on my wife's Vette along with an old (but clean) wool pad. The minute I fired it up I knew it wasn't going to get the job done, now it's at the dump. Bought one of Griot's kits and now detailing is major fun, the results are amazing and his buffer/products are great! wwwgariotsgarage.com or 800-345-5789
Gary
Gary
