best way to keep my headlights clean
Old Dec 12, 2010 | 03:39 PM
lunatyk's Avatar
^^ I sanded my down as well. Work your way up to as fine as possible, plastx it, and polish. Best with a buffer.
Old Dec 22, 2010 | 03:13 AM
Boosted D.D.'s Avatar
Toothpaste works also
Old Dec 22, 2010 | 03:28 AM
liljohnny's Avatar
Originally Posted by IrockAG35
also just an fyi..if u do come across yellowing in ur projectors(havent seen a set yet) the 03-05 lenses are swappable with the 06+...another somewhat cheap easy fix
Don't want to question a senior member but really? I thought 06+'s had a different shape than the 03 -05's..........
Old Dec 22, 2010 | 09:07 PM
dcryan90's Avatar
Originally Posted by gary c
OMG....you NOOBS forgot to mention sandpaper! Your headlight covers will last a very long time by just normal wash and wax. I wouldn't use a cleaner wax just a quality carnauba wax to protect them from the elements.
Gary
Really? sandpaper? Ive only seen that done to cheap cars or cars that are so far gone that you can barely see behind the lense... if your keeping up with your car a simple polish will work no doubt it really shouldnt be a big deal ever unless you buy a car that has already yellowed really bad.
Old Dec 26, 2010 | 07:18 PM
noooorb's Avatar
For long-term preventive maintenance I recommend 303 Aerospace protectant once a month
Old Jan 3, 2011 | 09:34 AM
stabadus's Avatar
+2 on toothpaste
Old Jan 3, 2011 | 04:06 PM
redwillow's Avatar
20 Year Member
toothpaste
Old Jan 3, 2011 | 09:49 PM
G-thang1105's Avatar
megs plastx keeps mine good and clear
Old Jan 3, 2011 | 11:30 PM
TORETTO's Avatar
While this thread is here, anyone know how fix the condition of headlights that seem like a clearcoat on it is coming off?
This is what I have
Old Jan 4, 2011 | 01:00 AM
LUSTR's Avatar
From my experience best is to seal the headlights with something like Blackfire Wet Diamond, Klasse Sealant Glaze, etc. every time you wash the car. Due to the heat the sealant won't last as long as it would on your paint, so sealing them often will keep them protected always.
If/when they start to look yellow, rock chipped, etc., sanding then machine polishing works well. Make sure you know what you're doing it or take it to someone that does though. Oh and once you've "fixed" the lights with sanding and polishing, you've usually taken off any UV protection the plastic was coated with, so you'll need to seal them much more often to keep them fresh.
Hope that helps.
Old Jan 7, 2011 | 04:17 PM
Golden_Shower's Avatar
Can you clear bra a headlight, that seems like it would protect it but I don't know about the heat.
Old Jan 7, 2011 | 05:06 PM
DrewLe's Avatar
This is what I have
That's the exact same thing that's happening to mine. And I can't seem to get it off or go away...
Old Jan 23, 2011 | 03:06 AM
nismoz's Avatar
Absolutely Yes. My HLs have clear bra on them and they are great. The clear bra will not cover entire surface but it will cover almost (98%) of the surface of the lens except for some outside area. But well, it is acceptable. And it works well against rocks, weather... I would highly recommend clear bra. My HLs still have the rainbow look (colors) every time I look at it at under sunlight. I still wax them every time I wash my car
Old Jan 23, 2011 | 03:22 AM
TORETTO's Avatar
I might just sand mine with very fine sandpaper and see if that fixes it. It's likely the clearcoat that is chipping off, so polishing/waxing doesn't fix it. At least, I've tried and it hasn't worked.
But when stripping off the clearcoat, that just means I have to work even harder to keep them in good condition once I sand it down.
Old Jan 23, 2011 | 03:41 AM
  #30
DrewLe's Avatar
Yeah, it's around the edges like yours. Don't wanna use anything too abrasive where it'll take the clearcoat and UV protection off, so like you said, will be harder to keep in good condition. I might ending up using toothpaste myself and see if that'll help.
