Spots on OEM Rims
Old Nov 8, 2004 | 11:37 AM
charog's Avatar
Spots on OEM Rims
Recently after it had rained here, my rims later had some spots on them. I tried washing them off with soap and water, but the spots seem to be within the finish. Do any of you know of any special cleaners to clean the rims without damaging them ? Thanks.
Charog
"I'll Be Your Huckleberry"
Old Nov 8, 2004 | 06:08 PM
P_Diddy's Avatar
Re: Spots on OEM Rims
hmm, maybe you can try to claybar them? Some people have used diluted SimpleGreen on their wheels too.
Let us know what works (or doesn't work)!
good luck.
2004.5 6MT DG/G Coupe | Premium | Aero Kit | ClearBra | See profile for pix
Old Nov 9, 2004 | 02:39 PM
Diesel1's Avatar
Moderator
I have gotten the same thing on mine as well, but oddly enough, only the 2 rear wheels!!!! Looks kinda like those spots old people get (liver spots I think). Anyway, I only use soap and water on my wheels so I know it wasn't from any chemicals!
www.gsquad.org
Old Nov 10, 2004 | 11:08 AM
charog's Avatar
I had the dealer try to remove the spots, but they could not remove them. I will try using a clay bar or another cleaner. I'll let you guys know. Likely it happened after it rained here in LA.
Charog
Old Aug 17, 2005 | 01:39 PM
wc7718's Avatar
Any luck on cleaning the dark runs that seem to sit under the clear coat of the rims? I tried the Meguires Hot Rims Cool Care All Wheel Cleaner to no effect. I have the 05 OEM forged 19's.
I asked the dealer about this and they come across quite a few with this issue... some more severe than mine. Apparently, Infiniti doesn't have a clue and won't warranty it.
Old Aug 17, 2005 | 02:01 PM
jimcambell's Avatar
Any chance of getting a pic of what you are seeing?
I took my wheels off within 3 days of having ghe car and did a coat of metal polish and sealant on them. I'll be doing the same again before storing them for the winter, and then again next spring before swapping out the winter setup.
The old saying, an ounce of prevention is worth a pound of cure definitely holds true for car care!!!
Old Aug 18, 2005 | 10:14 AM
Punchit's Avatar
Jim, I noticed that you often have good detailing advice and I think your right on here again. Usually a metal polish like P21S Finish Restorer will take out those spots. Wheel cleaners generally can't work that deep into the surface. Also Just like Jim said a coat of wheel wax or a wheel sealant will prevent this from happening in the future. I apply a coat about 3-4 months and it keeps the wheels looking great and very easy to clean. The Poorboy's Wheel Sealant is by far one of my favorite products out there right now. This 8 ounces of protection is definitely worth a pound of cure (Sorry I had to throw that bad pun in there).
Xfactor
Dec 1, 2019 12:52 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
leo38cheng
Aug 9, 2015 12:14 PM
