meguiars detailer spray
Old Nov 12, 2004 | 10:59 AM
mikeyg's Avatar
when should i spray this on my car? i have heard wash, spray detailer on when wet, dry, wax let me know if this is right thanks guys
Old Nov 12, 2004 | 07:27 PM
fldrummer's Avatar
Re: meguiars detailer spray
It should be used after the car is washed and dry and can also be used between washes for touch-ups. It helps keep up the shine on an already waxed surface. You can also use it as a lubricant for a clay bar before waxing.
2004 6MT (Silver/Willow), premium & aero packages
My old ride (I still miss her; put a lot of pride and joy into it): http://www.n-body.net/registry/john95ga/
Old Nov 17, 2004 | 02:54 PM
mikeyg's Avatar
would i be able to use it fter washing and drying the car and then apply wax after i apply the detailer and wipe it off?...im only asking cause i wax my car every time i was my car which is every week
Old Nov 17, 2004 | 08:22 PM
Diesel1's Avatar
Moderator
If you wax every time you wash, you can use it just before waxing to make the wax apply easier, but then again if you wax every week, you may not need to. Keep in in your trunk (becareful on hot days when it will build pressure and possibly leak), and use it to remove bird crap and fingerprints! I would be careful using it between washings because if the car is dusty/dirty, you'll be moving that dirt around on the paint, thereby creating scratches...etc.
www.gsquad.org
Dallsinghjr1
Sep 17, 2023 11:25 AM
g.spot
May 9, 2016 10:54 PM
Jeff T
Sep 30, 2015 02:00 PM
