Ink removal on headliner???
Old Sep 5, 2011 | 04:11 PM
RMA's Avatar
RMA
I noticed a ball point pen mark on the sunroof shade area. What do you guys recommend for ink removal that is not damaging to the material of the sunshade?
Old Feb 20, 2012 | 01:11 AM
jackjroadster's Avatar
RMA! hi. we're you able to remove the ink stain on your headliner? what did you use for it? even if it is just a ball point mark? mine is so much larger and messier because i got it from those darn ink printer cartridges. my kiddos sort of played with it and it got thru the headliner.
Old Feb 21, 2012 | 03:16 PM
RMA's Avatar
RMA
Ballpoint ink mark still remains, I never got around to cleaning it off. Any ideas on here for you detial pro's?
Old Feb 21, 2012 | 03:22 PM
GAU-8's Avatar
Aerosol hairspray.
Old Feb 21, 2012 | 05:01 PM
finallygot1's Avatar
Something orange oil based will work wonders
Old Feb 21, 2012 | 05:15 PM
RMA's Avatar
RMA
How about Shout ?
Old Feb 21, 2012 | 05:26 PM
856_reilly's Avatar
lacquer thinner it's the only way trust me it will be your bestfriend!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 23, 2012 | 03:35 AM
dimsler's Avatar
There is nothing that won't take out the ink out without removing the dye out of the headliner at the same time, or worse, melt/un-glue the fabric from the cast foam back plate.. Ink woks just like a dye, you can try to carefully bleach it out, and re-color the area.
Old Feb 23, 2012 | 09:06 AM
GAU-8's Avatar
I have used hairspray on several materials and surfaces. If you saturate the spot and let it sit for about 30 seconds, then lightly wipe and blot the area to pull the hairspray out of the material. You might have to use the whole can, but a $3 can of hairspray is much more affordable than paying someone to re-glue or replace your headliner. Look it up. It's one of those low cost home repairs no one really thinks about.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
dcsbh1
Oct 1, 2015 03:15 PM
