Paint/Clear Coat Damage or Not?
Old Jan 20, 2012 | 09:11 AM
beretta01's Avatar
Unhappy Paint/Clear Coat Damage or Not?
Hey all, a couple of years ago I decided to debadge the "G35" from my trunk....I really didn't have a clue back then and tried to remove the ghosting with alot of Scratch X; I probably did so 3 times before this weird problem(pictured below) arised. It is smooth but it appears as if there are little clear splotches that surrounds the upper left part of the "3". Like I said, it was a few years ago and I am hesitant to try anthing else to make it worse because right now it is only visible at the right angle and light condition. My intent was obviously to remove the ghosting which, as you can see, is still there after 2 years!! Any help would be greatly appreciated, thanks!!
Old Jan 20, 2012 | 12:01 PM
Detailed Image's Avatar
Not sure what the clear spolotches are, I wasn't able to see them in the picture. Assuming the clear coat is intact and you don't think there is any damage to it I would use a different polish combo. The Scratch X is a pretty mild polish. I would use the Meguiar's Ultra Finishing Polish M205 which is a better light polish in my opinion. If that is enough the Meguiar's Ultra-Cut Compound M105 will almost certainly remove the ghosting. When you are done the surface should look optically clear with no more ghosting. Let me know if you have any other questions and I'll be happy to help.
Greg @ DI
Old Jan 20, 2012 | 12:06 PM
beretta01's Avatar
Thank you, Greg! I will give it a shot and report back.
Old Jan 21, 2012 | 09:16 AM
beretta01's Avatar
So, I put just a little polish on it this morning for about 15 seconds and what resulted is pictured below. I stopped immediately because, quite honestly, I was a little scared to go any further, but it IS smooth to the touch. Any ideas/insight!?
Old Jan 21, 2012 | 10:46 AM
flyz's Avatar
Is the car parked outside in the sun? It looks like paint fading to me with the lettering being darker than the surrounding paint.
You won't get that out with polish.
Old Jan 21, 2012 | 02:22 PM
beretta01's Avatar
It is! But the thing is, there are 3 distinct colors of the paint: paint that was under debadge, normal paint, and then this whitish gray area in question. If it were paint fading, would it not just be 2 shades, ie paint under debadge and paint outside debadge? It is VERY visible right now after applying polish for the 15 or so seconds! :/
Old Jan 21, 2012 | 02:25 PM
G35SedanGrn's Avatar
get it repainted or just put the G35 back on...
Old Jan 21, 2012 | 02:36 PM
beretta01's Avatar
Ugh, that's what I was hoping NOT to hear lol!! What do you think is happening with it? It's just strange because it is still smooth and glossy, I'm pretty puzzled with this one...thank you all for the comments!!
Old Jan 21, 2012 | 02:38 PM
looks like the paint it just faded :/
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
