Required Rust Treatment suggestions from your experience
Old May 25, 2013 | 07:52 PM
achilles333's Avatar
Hi,
I have 2004 G35 coupe. I ignored the chips caused by rocks & snow salt in winter. And now I observe the metal is rusted. I'm attaching photos & please suggest from your experience what treatment should be done!
1) what is the temporary treatment to prevent worsening?
2)Is this DIY possible?
3) If I take to body shop what is the estimated cost! ( knowing price here helps me whether the technician in body shop is charging right price)
thank you!
Attached Thumbnails Required Rust Treatment suggestions from your experience-13050007.jpg   Required Rust Treatment suggestions from your experience-13050008.jpg   Required Rust Treatment suggestions from your experience-13050009.jpg   Required Rust Treatment suggestions from your experience-13050010.jpg   Required Rust Treatment suggestions from your experience-13050011.jpg
Old May 26, 2013 | 10:09 AM
onthe3rdday's Avatar
That is pretty serious. Way past DIY stage you are at the point where that metal will need to be cut away in certain spots. Also, you need tires, BADLY. Unfortunately I cannot help you on price.
Old May 26, 2013 | 11:44 AM
Texasscout's Avatar
Wow......
I feel for you guys that live in salted road areas.
If your fenders are that bad, you need to put it on a lift and look around. My guess is, there is a LOT more underneath. As for tires, thye look old and almost worn out, they may pass inspection <2/32" but not by much. The weather cracking is a dead giveaway.
Good luck.
Old May 28, 2013 | 12:15 PM
Hi all,
Thanks for your suggestions. I am very glad you guys told about the tires. I will try to change tires as quick as possible! any suggestions on good tires..(old ones didn't turn out well )
cmesidewayz
Sep 29, 2015 09:28 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
Mhacker
Sep 12, 2015 07:35 PM
kevintandmd
Sep 3, 2015 06:41 PM
