ironx - rail dust, surface rust spots, rotor rust
Old Aug 3, 2013 | 06:24 PM
SiouxFallsG35's Avatar
I've always had small surface rust spots from the front wheels back on my cars. I attribute this partially to hand washing which allows time for a visible rust buildup on the rotors. The rust then flys off when braking and some of it deposits on the car. It appears on plastic mirrors and bumpers so I know it's a surface deposit. Getting it off with a clay bar is close to impossible.
I heard about ironx (iron x) and wanted to try it. Followed the instructions on the bottle using a giant household sponge and was completely satisfied with the results. The fluid is clear and immediately turns purple on all the rust spots, definitely not a gimmick. Google it if you want to see a video and discussions on other forums. I'm not aware of anything else out there that takes care of these surface rust spots so easily. I had 6yrs of build up and it required no elbo grease what-so-ever.
One thing to watch out for on our cars is the plastic/rubber piece that runs along the bottom side of our doors. The ironx got inside there and was bleeding purple out one end no matter how much I tried to spray it out. I had to spend a good deal of time blasting it out with water and compressed air. That piece should probably be removed before using this product.
Old Aug 3, 2013 | 08:14 PM
RCL's Avatar
RCL
Yeah its a great product, just very expensive to buy and use. I use about .2-.3L to clean the wheels alone. Using it to decon the paint would prob be atleast .5L, something I wish I could do more often but just isn't cost effective to me.
Old Aug 17, 2013 | 02:36 AM
wallofgrath's Avatar
Did you try regular polish..?
Old Aug 17, 2013 | 09:38 AM
I can tell you that Klasse AIO (which contains a polish) by hand won't cut it. This ironX stuff takes care of it with no elbo grease what-so-ever. I did burn through half a bottle though and cost is an issue. I certainly won't be using it every year.
Old Aug 17, 2013 | 04:16 PM
RCL's Avatar
RCL
I wish there was a cheaper alternative but I don't know of one. But for now I just wash/clay/polish/LSP.
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
Visionnn
Oct 3, 2015 05:16 AM
dcsbh1
Oct 1, 2015 03:15 PM
