Waxing with an electrical buffer.
Old Apr 23, 2005 | 05:18 AM
baomao123's Avatar
Has anyone ever used an electrical buffer (similar to the professional ones used at a car wash or professional detailing place) to wax their car?
I am thinking about purchasing one. However, I know they are kind of expensive and wanted to know how well they work.
If you have bought one of these machines, please tell me where you bought it from and for how much. Thanks.
Old Apr 23, 2005 | 11:16 AM
Diesel1's Avatar
Moderator
Be sure to only get an orbital type machine. Many have rave reviews about the porter cable. I just picked up the cyclo, dual head random orbit polisher, counter roatating heads (commercial grade - once in a lifetime purchase) from www.detailingdynamics.com I got the premium kit which included the polishes n sealents, foam pads, MF towels, etc etc. I paid about $350 for everything delivered. The Porter cable runs in the low 100's and then you would have to buy the pads chemicals etc. Probably run somewhere a lil over $150 all said and done. I recently used the Cyclo on my G and it worked great. Especially for the first time using it. It's a lil heavy, but again it's a commercial machine.
Old Apr 23, 2005 | 11:42 AM
G35_coupe_6MT's Avatar
im too much of a chicken to try orbital on my car...
Old Apr 23, 2005 | 12:10 PM
mizzoutiger's Avatar
Porter Cable 7424 Ultimate Detailing Machine Kit ... works like a champ
http://www.properautocare.com/74uldema.html
Old Apr 25, 2005 | 12:18 AM
BlackonBlackG35's Avatar
amazon.com sells for $120.
Amazon Amazon
Old May 1, 2005 | 09:31 PM
newtlicious's Avatar
Don't sweat it dude, orbitals are harmless unless you put a scotch brite pad on one . It's the high speed orbitals that require a deft touch. Get yourself an orbital, backing plate and some good pads like Sonus or Lake Country. Buy some Menzerna Intensive polish and Final Polish II and set aside a saturday. You'll thank me. PM me if you have ANY detailing questions, I know alot of tricks.
Old May 1, 2005 | 11:40 PM
tomheo's Avatar
Hey baomao123,
As others have suggested, I recommend a Porter Cable Random Orbital polisher. I have the 7336 which is the same as the 7424 except has a different counter-weight...7336 is compatible with 6"-6.5" pads, 7424 is for 5" pads...you can swap out the $3 counter-weight on either one. I bought it at Lowes for around $100.
As long as you use the correct pads, it's pretty worry-free. Check out autopia-carcare.com for some good tips on how to use the polisher. Just get a backing plate (has velcro on it so you can swap pads easily) and foam pads. Backing plates probably run about $15 and pads run around $12. You probably also want a microfiber bonnet if you wanna use the polisher for applying polish, but just check the various detailing sites and they'll be able to recommend the correct stuff.
Hope this helps.
Thomas
Freeman186
Sep 6, 2023 10:07 AM
Danielek
May 1, 2022 01:28 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
vamarris
Sep 26, 2015 12:56 PM
