Remove Pinstriping
Old Sep 30, 2005 | 11:14 PM
BocaCoupe's Avatar
G's Up, Ho's Down
Remove Pinstriping
I finally decided to remove my pinstripe. Anyone know how best to do so?
Old Oct 1, 2005 | 05:41 PM
Punchit's Avatar
Done it several times, I use a blow dryer to heat it up and that loosens it significantly, should be enough to peal it right off. Sometimes I use the 3M adhesive Remover (found at any hardware store) to remove the stripe and the residue. You can also use mineral spirits, WD-40 but that works best IMO.
Old Oct 4, 2005 | 07:35 AM
Blackjack's Avatar
A G with pinstriping. Never seen that before, but definitely remove it. I can't imagine it looking that great. Punchit is right: heat from a blow dryer and some sort of adhesive remover. Be sure to polish and wax after removing the pinstriping to protect the area that never was protected.
Old Oct 4, 2005 | 10:44 AM
Punchit's Avatar
Good point I forgot to add that you should polish the area with a medium to mild abrasive polish after to blend it in. The Poorboy's World SSR 2.0 or 1.0 should be perfect for the job. After you've polished the area I would protect it with a sealant instead of a wax because of their increased durability.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
