how to wax?????
Old Mar 29, 2006 | 09:51 PM
JoEY C's Avatar
how to wax?????
well guys just pick up my 06 dg coupe on fri. and its time to wash and wax it...how do you guys suggest to wax it in circular motion or side to side????
Old Mar 29, 2006 | 10:05 PM
MD_V35's Avatar
http://www.autopia.org is where i found all the info i needed.
Old Mar 29, 2006 | 11:08 PM
Andy2434's Avatar
I wax in a back and forth direction inline with the car.
Old Mar 30, 2006 | 09:03 AM
JoEY C's Avatar
Thanks Guy Anyone Else???????
Old Mar 30, 2006 | 09:19 AM
GTScott's Avatar
Autopia.org is where to start. however, you will want to look for specific things. Look for information on the 2 bucket wash method, grit guards, and lambswool mits. That will get you through the wash. Look for info on waffle weave drying towels to get it dry.
As far as waxing goes, assuming you don't need to polish first, waxing is pretty easy once you pick the applicator that works best for you. I like microfiber pads for most liquid waxes and sealants and foam for the pastes. Most products make a suggestion as to what you should use.
I agree with the previous posts, you want to avoid circular motions.
Best of luck!
-GT
Old Mar 30, 2006 | 10:27 AM
JoEY C's Avatar
Sounds Good Thanks
Old Mar 30, 2006 | 11:56 PM
JoEY C's Avatar
i heard this is the way to go...wash, dry, wax...trunk, hood, and top of car front to back...and doors, back, and front of the car go up and down is this true????
Old Mar 31, 2006 | 08:49 AM
GTScott's Avatar
I am not sure I understood your question, but if you are talking about washing order, yes. Start high (where there is thought to be less grime) and work down. Also, be sure to use a seperate set of buckets for the wheels, tires, and any other heavily grime-ladden areas. Try not to apply much pressure to your wash mit also. This will help to reduce the liklihood of scratches.
-GT
Tmatheso
Dec 13, 2015 03:24 PM
TNRocker
Sep 21, 2015 08:36 AM
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 11:25 PM
bigmike
Sep 17, 2015 01:58 PM
