Scuffs on Clear Coat
Old Mar 31, 2006 | 06:13 PM
Mufi's Avatar
I have a small spot where I can see very light scuffs on the clear coat. It isn't really swirl marks. It's kind of like swirl marks in a sense that it isn't really deep. It's a small patch that something must've slightly rubbed against. I can only see it if I look at the spot in an angle to allow light to reflect off of it. Is there any cleaning solution that I could do to fix this problem? Thanks.
Old Apr 1, 2006 | 12:39 PM
Punchit's Avatar
Probably need a polish I remove scuffs with Poorboy's World SSR 2.5 followed by the SSR 1.0. This removes just about any scuff that can be taken out. Really easy to work with and a great shine, can't go wrong.
Old Apr 2, 2006 | 03:58 PM
GTScott's Avatar
Before going to an abrasive, I would try clay. If it truly is a scuff, there is probably something sitting on the surface and the clay will remove it. If it is a series of scratches, a light polish would be my first suggestion. If that does not work, go up a notch until you end up with a swirl remover if needed. As of this weekend, Menzerna FP is my favorite for removing defects from ultra-soft clearcoated cars.
-GT
Old Apr 2, 2006 | 04:01 PM
2FastG354U's Avatar
Where can I buy a swirl remover?
Old Apr 3, 2006 | 08:13 AM
GTScott's Avatar
If you really want to go to a swirl remover, a stronger polish like the Menzerna IP or FP can be had at www.properautocare.com. A true swirl remover like Poorboy's can be had at www.poorboysworld.com. On the PB stuff, I would think that you would not want to go any more abrasive than SR2. I use 2.5 on harder clear and it works quick. With the SR/SSR line, you just have to remember to work them long enough as they break down as you work and thus finish cleaner.
-GT
Old Apr 4, 2006 | 02:45 AM
ksig113's Avatar
Menzerna IP and FP works well to remove swirls, but don't use it too much because it is very strong.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
