DFW G35 on the dyno
Old Dec 23, 2007 | 04:22 PM
waijai's Avatar
i.love.gold
DFW G35 on the dyno
So I went to get a few runs today after fixing my belt slip issue. It looks as though my UTEC is sensing a bit of knock after 5.5k rpm and pulling timing which kills power. I'm not sure if it was just a bad batch of gas, but I only hit like 345whp. I also have a miniscule exhaust leak, which might be causing false knock. I will fix that this week as well along w/ swapping out my plugs as German told me to do.
Props to Cameron at Matchless
Old Dec 23, 2007 | 05:21 PM
Mark350GT's Avatar
nice, when i get back i think i may jump on the dyno and make sure everything is running properly.
Old Dec 23, 2007 | 05:25 PM
waijai's Avatar
i.love.gold
Your oil leak is fixed Mark...saw it last night at the shop.
Old Dec 24, 2007 | 11:51 AM
waijai's Avatar
i.love.gold
I guess I can retitle this thread: "g35man04's new front bumper" Who cares about the car on the dyno.
Old Dec 24, 2007 | 11:56 AM
BlueBOB's Avatar
numbers look good will... not sure how much the little problems will fix thing
Old Dec 24, 2007 | 12:26 PM
BeerViper's Avatar
ROFL, I didn't even realize that I replied to the OT post from g35man04!!!
So is this the first official dyno run since the UTEC USB issue? How many psi is being registered at the plenum? I would think your numbers should definitely be higher but thankfully timing is being pulled to save the motor when knock is detected!!!
Did you do that mod that added the additional pulley next to the jackshaft pulley???
Old Dec 24, 2007 | 12:37 PM
waijai's Avatar
i.love.gold
Well, the USB issue was resolved previously and it only put down 301whp at 5psi. First official dyno run since my belt slip issues, and I am not getting belt slip with the new pulley mod. I think I can hit 9psi a little past redline, as I have my rev limiter set to 6700.
Old Dec 24, 2007 | 12:45 PM
Bigd2k6's Avatar
didn't mean to leave you out, moog. nice numbers btw should've put some pictures of the whole car up as well--it's easy on the eyes. i did have a question for you too though: your yellow fogs are nice but how do the highbeams look once the fogs switch off? is it just a brighter yellow and how does it look?
Old Dec 24, 2007 | 12:46 PM
waijai's Avatar
i.love.gold
It's the same yellow, just brighter with the second filament turning on in the H4 bulb.
Old Dec 24, 2007 | 02:16 PM
BlueBOB's Avatar
ya know, I've been meaning to ask about that... i swore my 06 when i first bought it used the fogs as high beams as well... however, I've done the recall on them and now they use the HID with just a reflective plate... was i losing my mind or did they switch as apart of the recall?
Old Dec 24, 2007 | 02:48 PM
CoppellStereo's Avatar
wow there are some hot Gs in dallas
Old Dec 24, 2007 | 03:08 PM
waijai's Avatar
i.love.gold
I don't think they switched anything in the recall besides some alignment type stuff. Not 100% sure though, as I have an 03.
Old Dec 24, 2007 | 03:19 PM
BlueBOB's Avatar
Yea, the recall was just because the light was too high... ghey
but i swear the fog was the high beam prior to the swap...
Old Dec 24, 2007 | 03:53 PM
Mark350GT's Avatar
nice, thank god for that. It was a high pressure line from one of the turbos that got fu<ked up. Any updates on anything else on the car? My VDC and ABS madness sorted out?
Old Dec 24, 2007 | 03:59 PM
Mark350GT's Avatar
Originally Posted by g35man04
damn i still have yet to see your car Mark....I want to so bad!
I am looking forward to seeing yours also. I have updated quite a few things on mine for 08 so i hope that we can all meet up in jan for the meet. Should be a good time!
