How do these numbers compare...
Old Mar 16, 2008 | 11:48 PM
Da Prez's Avatar
i dynoed my car at the HPP charity dyno event sat, and it put down 227/225... is that about par for what an 06 5at g should put down?
Old Mar 18, 2008 | 09:59 AM
BeerViper's Avatar
I'm trying to remember what my '04 6MT put down when it was stock ... I want to say it was around 235/225 so your numbers are about right on par.
There's a lot of variables when the dyno operator is setting up the run, they need to accurately enter the weight of the car which creates a correction factor.
Now you've got a good baseline to start doing some mods and see how much hp per dollar you can get
Old Mar 18, 2008 | 03:37 PM
Da Prez's Avatar
whats gonna be the best bang for the buck? ive bought an aem intake, and looking for my next mod, maybe exhaust...
Old Mar 18, 2008 | 03:51 PM
BeerViper's Avatar
Best bang for the buck? A cheap used supercharger or turbo
But without spending several thousand, I'd say just about the best mod for the buck is a plenum spacer. Replacing the manifold in addition to a spacer can yield significant increases in HP and TQ. Check out Motordyne's collection: http://www.motordyneengineering.com/G35.htm
Old Mar 18, 2008 | 04:45 PM
Da Prez's Avatar
i would love to turbo the G, my buddy who runs HPP turboed his 350 and that thing would haul some serious *****...
thanks for the link, looks like i will be ordering an manifold and spacer....
Old Mar 18, 2008 | 10:55 PM
G35StrongMan's Avatar
Cool
2003 to 2006 5ATs have the same motor. You would only need to buy the spacer. If you do the MREV manifold, you might run too lean.
The 1/2" spacer gave me 15HP and 17FT on the dyno. Check out my dyno
https://g35driver.com/forums/showpos...9&postcount=17
Old Mar 18, 2008 | 11:21 PM
BeerViper's Avatar
You really don't think the ECU would make up for the increased airflow? Or is it because the increase is already after the MAF sensor?
I'm also running the 1/2" MD spacer but results are typically different with FI.
Old Mar 19, 2008 | 10:27 PM
Here's one of the posts that made me send back my MREV2 manifold over a year ago. I never installed the manifold.
https://g35driver.com/forums/showthr...ighlight=mrev2
My car runs an A/F of 15.1 just before 3300RPM. Once it goes into closed loop, it drops to 12.X. I had the dyno sheet that showed it, but it was miss placed when I moved.
Old Mar 20, 2008 | 12:40 AM
BeerViper's Avatar
That's some interesting stuff. However, I agree with one of the posts that there is no way that a bolt on could require you to go with larger injectors. I'm running Vortech with stock injectors...
Old Mar 20, 2008 | 03:30 PM
jran76's Avatar
If he has a 5AT then the motor is a non-revup. The MREV2 is only used on the revup engines. With the 5AT the spacer is the only thing needed. In terms of power I would do this before the exhaust.
suby01
Not G35 Related
May 25, 2016 03:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
