music/file format experts
Old Jun 16, 2009 | 12:08 PM
syshs's Avatar
I have downloaded some songs/tracks off of the internet... some of these tracks are over 2 hrs long (trance/house music mixes).
Some of them dont allow me skip to the middle of the track. If I try to, it goes to the beginning of the track.
Does anybody know if I have can fix that, by changing the format or properties or something?
TIA
Old Jun 16, 2009 | 01:48 PM
dc78chs's Avatar
What format are they in?? (MP3 WAV...)
I can fix it for you... I would need the song and what i would do is break it down into several tracks so instead of having one big @ss track (2 Hrs) i would do like 10 Minute tracks until the end of the song...
but anyways i can fix it..
Send me a text...
Old Jun 16, 2009 | 02:51 PM
syshs's Avatar
^ Hey Danny,
Its .flv, I changed it to .mp3, but same issue.
Well, ideally, I would want to be able to just jump anywhere in the track (like how you can usually do to all other tracks).
Can you do that?
Old Jun 16, 2009 | 04:10 PM
Mad A's Avatar
That's odd, you converted to an Mp3 and you still can't skip forward or backward?
Host the file up somewhere and let me take a crack at it.
also what program did you use to convert it?
Old Jun 16, 2009 | 05:30 PM
dc78chs's Avatar
^^^ Ya what program did u use to convert it...?
Did it work after you coveted it???
That's weird because FLV is Flash Video...
Old Jun 16, 2009 | 05:57 PM
syshs's Avatar
^ Yes, I downloaded the songs from a website. The files are .flv.
I opened them in my VLC player and can listen to them, but I cant skip to the middle of the file.
I didnt actually change the format or convert it, I just renamed the file extension to .mp3 and that didnt help... as in I can still listen the the file, but cant skip around.
Old Jun 16, 2009 | 06:10 PM
twalls's Avatar
CLUB MODERATOR
if you load the file as audio into like audacity (free) or cubase or even fruity loops you can split it up into separate wavs and convert it back to mp3..
Old Jun 16, 2009 | 06:14 PM
syshs's Avatar
^ Yes, I think that what the issue is. I have to properly convert it a mp3 file.
So, what software should I use to do that? Audacity?
Old Jun 16, 2009 | 06:16 PM
syshs's Avatar
Dang Tones, I just noticed, you joined g35drivr exactly 1 yr aft me and are only 100 posts behind me, haha!
Old Jun 16, 2009 | 06:28 PM
twalls's Avatar
CLUB MODERATOR
Heheheheheh.. It's an addiction.. how I've learned so much so fast though.. <bows humbly>
I believe you can just import the flv file into audacity as audio, and then preview the audio (listen to it play) and then "cut" it how you want.. and save each slice as it's own file by exporting the selected portion as an MP3.
That should be easy..
Old Jun 16, 2009 | 10:59 PM
g35driver76039's Avatar
are the a state of trance episodes? or some live mixes
TIA
Old Jun 16, 2009 | 11:27 PM
syshs's Avatar
Global DJ Broadcast mixes by Markus Schulz recorded live.
Alright, I will give it a shot tonite or tomorrow. Thanks.
Old Jun 17, 2009 | 12:46 AM
syshs's Avatar
Found this... http://www.convertflvtomp3.com/
Worked like a charm.
untz untz untz
untz untz untz
untz untz untz
Old Jun 17, 2009 | 01:04 AM
syshs's Avatar
If you like Trance/House/Dance music, check out Global DJ Broadcast mixes... its addictive... esp this lady in a british accent comes in between mixes and says "Globbaalll DJ Brooaddcassst". Some good shiz.
Old Jun 17, 2009 | 02:50 AM
toeknee's Avatar
Untz untz untz =)
